LS Truck power steering to 3rd gen..which line for pressure side?
Old Dec 3, 2013 | 01:12 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Finishing up an LQ9 swap into my 87' IROC and I'm tryin to find a OEM power steering line (pressure side)that'll fit the LQ9's power steering pump and still thread into the IROC steering box..I read somewhere that the stock thirdgen line will work..can anybody confirm this?,if not..anybody got a part number for one that will work? TIA
Old Dec 3, 2013 | 08:03 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LS Truck power steering to 3rd gen..which line for pressure side?
Depends what pump you're using. If it's the old Saginaw pump like 3rd gens use, then the 3rd gen line will do. Some trucks had hydro boost systems, just cap the top return line. The newer trucks use the newer pumps like cars. You'll have to figure out a line for that
If using the 4th gen pump, use the 4th gen line
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
jackhammer
Aug 15, 2015 10:04 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
