Front crossmember and frame for LT1 swap
Old Feb 13, 2014 | 12:36 PM
swittke1217's Avatar
can anyone tell me if I can use the x member and frame frame from a 96 z28 to put under a 92 Camaro rs without having to change or modify the frame for the ac compresser also can I use the rear end from a 96 z28 to go under a 92 Camaro
Old Feb 13, 2014 | 12:59 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 305 TBI to LT1 conversion
Front ends are completely different, not interchangeable what so ever.
Rear end can be used, but is wider by 2", so tires may rub on wheel wells depending on what you have.
Old Feb 13, 2014 | 05:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moved this to its own thread instead of tacking it on to a 12-year-old thread.
If the AC compressor is your concern, you can either notch the stock K-member for clearance, or get a tubular K-member.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
