What else needed for t56?
Old Feb 13, 2014 | 08:26 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I'm trying to compile a list of everything needed for my LS1/t56 swap. I have most of the motor stuff. Now I am working on trans parts.
My pullout only came with the trans, no other trans parts.
So my list consists of
Trans
-Pedals
-Shifter
-Flywheel/Clutch/TO bearing
-Slave Cylinder
-Trans lines
-Hawks Double Hump Crossmember
-Trans mount
I have searched, but mostly come up with LT1 swaps, and I am trying not to confuse the non interchangeable clutch parts, plus this stuff is a little more advanced than the trans in my '70 sand rail
Old Feb 13, 2014 | 08:43 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: What else needed for t56?
All the bolts
Bellhousing to trans
Bellhousing to engine
flywheel to crank
PP to flywheel
Old Feb 13, 2014 | 08:46 PM
Warnd's Avatar
Car: 1992 z28
Also the rest of the clutch hydraulics. You listed the slave but you need the master and the line/resevoir that goes with it.
Old Feb 13, 2014 | 09:24 PM
Pocket's Avatar
Car: 91 Trans Am
Pilot bushing/bearing
Old Feb 14, 2014 | 09:59 AM
Axle/Gears: 4.10
OK. Thanks guys!
I think i've got everything then.
Trans
-Pedals
-Shifter
-Slave Cylinder
-Trans lines
-Trans mount
-All the bolts
-Master Cylinder and lines
-Pilot Bushing
Old Feb 14, 2014 | 10:54 AM
Pocket's Avatar
Car: 91 Trans Am
Just a tip, but autozone sells the same HTOB as GM for about $90. When you pick it up, make sure its cast alum with AP on the base. Painted black means china junk
Also, price out the master to slave line. Ive got one attached to a master in my swap parts thread. Pedals w/ switches too
Wouldnt hurt to get a remote bleeder while you're at it. $40-60 from most places
The stock hurst shifter from alot of 4th gens feels great and is relatively inexpensive
LS7 clutches feel great and are inexpensive
If you're keeping the TA mount on the tailhousing, Id skip the stock trans mount and use a HD mount from a 4L80E equipped truck. You will have to redrill the crossmember for 2 holes instead of one, but Ive never broken one and it dampens vibrations more than poly
Old Feb 14, 2014 | 01:17 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
The remote bleeder is always a good idea.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
hokis
Aug 9, 2015 03:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
