K-Member LS Swap Question
Car: 1990 IRoc Z
I have removed my K-member to notched for AC clearance for the LS swap. My question is since I have the K-member out already should I notch also to give more room for the fbody Oil pan? Thank You
Car: 87 Trans Am
Re: K-Member LS Swap Question
Guys are notching it for the pan since there is some movement as the vehicle flexes under use and it's already a tight fit.
I'll be notching mine for the oil pan when I get to that point.
Car: '88 Iroc-Z
Axle/Gears: 3.23 posi 10 bolt
Some have good clearance between the oil pan & k-member, & others don't. My F-body pan was touching, so I notched the k-member.
Car: 92 GTA
Transmission: A-4
First I've heard of issues with the fbody pan and stock K-member. Does it have to do with different brands of motor mounts?
NBrehm
Aug 5, 2015 07:57 PM
