Injector help please!!!
Old Mar 23, 2014 | 08:15 PM
sumnerslayer's Avatar
Car: 1982 Camaro Coupe, 2004 Grand Prix
Engine: 6.0 iron block LS, series III 3.8
Transmission: T56, 4T65-E
Axle/Gears: 3.42s<--hate em...need some 4.30s
OK so I posted in ls1 tech and the anwsers I got were conflicting and not really anymore pouring in and I need to find out in a hurry so if I have to order a different set I need to get the ball rolling. Here's my post.
Hey guys, I'm trying to pick out a set of injectors for my engine. This is my 1st attempt at a injected engine so any help will be greatly appreciated. I have a 2004 LQ4, internals are stock, LS6 intake w/24# injectors, ported TB, screen less MAF, LT headers and straight pipes all in a 82 Camaro with the T56. After I get the engine running and make sure everything is sound I plan to add a cam this summer or fall. My question is will the 24# injectors feed this thing OK until I put a cam in it? Am I better off buying bigger injectors now? I haven't sent my ECM off to be tuned yet. Was waiting until I get the injectors figured out 1st and was planning on going with Frost for a tune unless somebody recommends another tuner. Thanks in advance for any help!! Also what rpm should I set for a limit with the stock cam?
There ya go boys, ANY help or insight will be greatly appreciated!!!
Old Mar 23, 2014 | 09:54 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: Injector help please!!!
In my opinion, 24 pound injectors will be boarder line if being able to keep up at WOT. For the sake of being safe and protecting your investment this far, I personally would upgrade injectors now.
As far as the limiter, your tuner should be able to give you sound advice and a good recommendation. I have heard nothing but good things about frost.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
