n00b question: knock sensor...
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I have my LQ4 almost done at the machine shop. I am doing a s475 with a carb blow-thru LQ4 with a TU2 cam. All assembled.. do I keep the knock sensors in the lifter valley or do I use something else? I am going to be running MSD-6010 ignition.
EDIT: The answer for my carb'd setup is a NO. do not need it... Found the answer on LS1Tech...just in case anyone wanted to know the answer.
Transmission: 4L80E/4L80E
I have no idea if MSD uses the knock sensors, but I guess I can say I'd be surprised if they don't.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
Ragtop Man
Sep 12, 2015 12:23 AM
