lt1 swap gauge question
Old Apr 13, 2014 | 03:56 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Trying to get things together to start my lt1 swap. Have entire lt1 460le out of impala ss with all harnesses. Going into an 87 trans am tpi car with digital dash. What must i do to retain my digital gauges
Old Apr 13, 2014 | 05:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: lt1 swap gauge question
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Apr 13, 2014 | 06:35 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
So is it safe to cut up my unmolested tpi harness or should i find a tbi or carb harness to use
Old Apr 13, 2014 | 09:21 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did you read the link?
"Buy a V6 or TBI harness and modify that one as they are significantly cheaper and the sale of the SD TPI harness should net you a good chunk back
Everything V6/TBI/TPI about your old harness is being removed"
Old Apr 13, 2014 | 09:38 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
I read that however mine is maf not sd
Old Apr 14, 2014 | 07:49 AM
Pocket's Avatar
Car: 91 Trans Am
"Buy a V6 or TBI harness and modify that one as they are significantly cheaper and the sale of the TPI harness should net you a good chunk back
Fixed
Old Apr 21, 2014 | 07:59 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Another question the ECM harness that goes through the fender, is there anything needed off that harness or can I just remove it, I have a carb harness screwed into the bulkhead and I have a carb ECM harness down at my brothers
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
