trying to pull lt1 out the bottom of 95camaro. need advice
Old Apr 20, 2014 | 09:18 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I'm stripping a 95 camaro z28 and I'm looking for a quick check list of things to do to pull the motor out the bottom of the car.
I figure I should be able to pull the car off the motor/trans(t56)/wheels and kmember.
I know similar is done often and I'm looking for just a list of things to do so I don't go missing something and get in a jam or break something.
Starting the list
-Remove PCM and engine harness
-Rad & Condenser
-Exhaust
-Driveshaft
-Steering Shaft
-optionally headers
not sure on all the kmember bolts etc..
Old Apr 20, 2014 | 10:52 PM
Pocket's Avatar
Car: 91 Trans Am
Re: trying to pull lt1 out the bottom of 95camaro. need advice
Leave the harness on the engine, radiator still installed
Unplug the harness, disconnect the fluid lines, brake lines near the k-member, ds, crossmember y-pipe. Drape the harness ends and PCM over the intake and lift the car off the drivetrain
Old Apr 21, 2014 | 05:05 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
so then I just made it a lot harder on myself lol.. Thanks. didn't think of the brake lines either
Old Apr 21, 2014 | 11:16 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Pretty much what Pocket said above, but I like to remove the radiator and condensor just in case. I think it also makes it easier to wrap the chain through the frame as there is less stuff in the way. Again not saying it is the only way, just the way I like to do it. I also remove the hood for a little easier access, but it is probably no big deal on a car you are going to scrap.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
formula_novice
Aug 18, 2015 08:48 PM
