Motor mount to block bolt size?!?!?!?
Old May 5, 2014 | 11:41 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I give up.....................
Best I can come up with is M10 - 1.50x 30mm.
Also found M10 - 1.50x 25mm
Can someone here positively confirm the correct bolt size for me(98 LS1)?
Also were all 4 holes used in the 4th gen applications or just 3 per side?
I have new GM mounts/clamshells, but since it was all missing I have no bolts and online searching is proving inconclusive, although I do think it would be one of the choices above. (course if my nephew didn't have my tap/die/gauge set I could check it myself)
Thanks in advance
Old May 6, 2014 | 07:24 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Motor mount to block bolt size?!?!?!?
The thread is M10x1.5mm, same as any M10 bolt on a LSx engine. LSx use 4 bolts per side on most applications
Grab an accy bolt and bottom it out in a mount boss, then mark its depth. Remove and measure. 25.4mm=1"
IIRC they're very short bolts, maybe not even 1". Worst case scenario you would need a few washers to take up the difference, or just grind the excess length off
FWIW, Id grab a metric tap/die set if you plan to continue playing with LSx engines. Ive used the same cheap harbor freight set for years. Never know when a bug will pack a hole with mud or a rusty bolt needs to be chased
Also, you box should be there today or tomorrow
jhawkeye
May 25, 2022 06:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
knight72
Aug 10, 2015 09:32 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
