Corvette fuel regulator?
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Hey all just got the motor in and working on the trans now. Wanted to stop in and look to see if everything works (shifter cable) and luckily it does but i figured while i was here if anyone could tell me what yrs the regulator is from on the corvette? Also do i need any other fittings? Thanks for the help, i did a quick search but no real luck on years. Thanks! Back to work!
Car: Camaro
Engine: 6.2L
Re: Corvette fuel regulator?
C5 Corvette, all the same iirc. The PN is in the sticky somewhere but say a 2001 stock C5 would be a safe bet. They use the push on clip style fitting common on pretty much everything 99+
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Awesome, thanks pocket. So that would be fuel in/out then return to regulator correct?
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
