Fuel Tank Grounding
Old Oct 9, 2014 | 08:44 PM
Black18Ice's Avatar
Fuel Tank Grounding
Does the ls1 plastic fuel tank need to be grounded? I know there is the solid mount on the filler hose but not sure about the tank. I was planning on using a bike tire tube as the tank strap insulator and didn't know how the tank grounded itself. I know my silverado has rubber on the straps and the camaro had some sort of material, just not sure about a ground wire.
Old Oct 9, 2014 | 10:12 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel Tank Grounding
The sender is the only electrical component and its got two grounds. Plastic is non-conductive, so grounding the tank does nothing
Old Oct 9, 2014 | 10:21 PM
Black18Ice's Avatar
I've just heard that it can build up static electricity. Kinda like a balloon would. Didn't think so but wanted to check.
Old Oct 9, 2014 | 10:32 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
3rd gen tank grounded the fuel gauge sender to the metal fuel tank. You will need to add a ground to the car body for the 4th gen fuel gauge sender.
Old Oct 9, 2014 | 10:34 PM
Black18Ice's Avatar
Yup, plan on that since I'm using the 4th gen bulk head. Thanks.
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
