LS swap oil pans
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
LS swap oil pans
Spohn k member a arms set up for drag, pulling tires 6 inches. Its there a cheaper bolt on oil pan i can use? Corvette, holley hot rod pan, gm hot rod pan etc
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: LS swap oil pans
BTW superchevyperformance.com is $198.50 for the Fbody pan then around 50 for the windage and pickup tube. not gonna find it anywhere cheaper then $250 with new bolts/gaskets etc. But even the LS2 or LS3 vette pan should fit with a tubular K
Jay
Jay
I thought c6 and c5 had the same pans. I would go with a c6 pan
C6 pans cost more than f body pans lol i wanted something cheaper
Car: 1987 Z28
C5's have a batwing pan (two styles, 1 piece and 2 piece) C6 had a pan similar to the Fbody pan, a tad shallower but a rounded at the front hump.
I have found very many C6 pans for cheap since they seem to be the pan that come on most GM crate LS motors.
Jay
Jay
I just look on ebay and they want 400 + for them. I will keep a eye open for them. C5 pans i can get but i will have some large headers dont know how it all will fit.
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
This is whats on my LQ4:
$169
http://www.improvedracing.com/oil-pa...ods-p-390.html
EDIT: sits too low if your car is lowered. I'll take pics and post it up so all can see.
$169
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
the first gen cadillac ctsv with the ls6 motors. oil pan fit w stock kmember and adpter plate mounts. its what i had on my car. if u can find one cheap. it works
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
