Coolant Cross over question.
Old Nov 1, 2014 | 04:38 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I have the truck cross over and the ls6 intake hits in the back. My question is can you just use rubber hose and move it all out of the way or do i need to spend some money? lol Trying to make this work. It hits in the back corner and doesnt seem to be a fix on the intake side. looks like the cross over is just flat out in the way. I was just going to cut the back out and use a T fitting and rubber hose to move it out of the way.
Old Nov 1, 2014 | 06:20 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Re: Coolant Cross over question.
why not just use the LS6 block off plugs for the rear? Don't worry about using the crossover tube.
http://www.summitracing.com/parts/nal-12602540
Old Nov 1, 2014 | 06:22 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
If you truly don't want to spend money, I've read of people shaving the bottom fins on the intake to fit. Or something like that. Search it on LS1tech.
Old Nov 1, 2014 | 07:27 PM
Pocket's Avatar
Car: 91 Trans Am
If you have the truck 4 corner steam line that points strait up, it doesnt fit any car intake without major bending. The LS6 crossover is inexpensive and the rear blockoffs dont appear to hurt anything. GM used the blockoffs for nearly 10 years on millions of engines
Old Nov 2, 2014 | 03:01 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
While I was on ls1 tech I did read you break the fins off in some applications. But my version doesn't seem to fit like pocket said. Also I was just a bit concerned because they always bring up the back 2 cylinders leaning out because of not running all 4 corners. That's why I figured I'd just use a rubber hose
Old Nov 2, 2014 | 05:27 AM
Pocket's Avatar
Car: 91 Trans Am
A cheap solution is the LS6 front crossover and a 05+ truck strait up front crossover mounted to the rear. Connect the F/R with a T
Old Nov 2, 2014 | 08:36 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I may have to try that just wanted to bounce some ideas around since just using a rubber hose isn't the best solution but if it works.. lol
Old Nov 2, 2014 | 09:04 AM
Pocket's Avatar
Car: 91 Trans Am
If you're not pushing the setup, why bother? My supercharged 6.0 used the rear blockoffs on a very aggressive tune and had no detonation issues
Old Nov 2, 2014 | 01:26 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
You're right, I just figured if it was there before I should just replace it. I just don't want any issues lol I have bad luck
Old Nov 5, 2014 | 01:09 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Yes, rubber hose works fine.
Old Nov 5, 2014 | 06:18 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I actually used my summit bucks and just got the ls6 crossover and the block offs. Since I was already up there I figured I should just grab them.
Old Nov 6, 2014 | 04:55 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I actually just went through this just for people that may also run into this issue (ls1 intake though)
I bent the tube down on the passenger rear until it sat on the vally cover, then ground the intake a tad (be careful its thin). Then for the front exit it basically points at the throttle body. I was able to twist it and bend it down so I can route it under the throttle body. I drilled and tapped above the water pump inlet for the steam tube.
Jay
sheachopper
Jul 31, 2019 11:27 AM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
