5.3 swap fuel system
Old Nov 15, 2014 | 04:48 AM
adamrivera94's Avatar
I've got a 5.3 going in my 84 camaro everything is almost done but I'm at a stand still on the fuel system! I'm running the stock 5.3 fuel rail with a 98 trans am metal ls1 fuel tank and pump! My question is how would I go about hooking it up? Can I just run fuel hose straight from the tank to the rail? Is there a return line on the stock 5.3 rail? I'm at a complete stand still on this one? Can someone please help me asap? Another thing is the pump has 4 hose connectors can I just block the rest and just use the feed and return lines? Do I need to use the charcoal canister?
Old Nov 16, 2014 | 01:32 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 swap fuel system
Assuming you have a solution for hood clearance on the 5.3 intake, truck rails come in two styles: return and returnless
Return is just like your stock fuel system, so youd need to build lines from the frame rail to the fuel rails. Its just as simple to replace your 30 y/o hardlines with 100% braided and go direct from the tank to fuel rails
Fittings to the tank vary. If its thread on, use the same an EFI 3rd gen would use, if its push connect, check out russell
3rd and 4th gen tanks have 4 fuel lines. Feed (3/8) return (5/16) vent and evap. Evap can be capped, the vent should have a vent valve on the end. If this line is capped, a vented gas cap is required
Charcoal canister is not required
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
jharrison5
Aug 19, 2015 05:53 PM
