tbi to lt1
tbi to lt1
Okay i have a 1994 gmc sierra c1500. I also have a 95 firebird formula with the lt1 4l60e combo i want to swap the lt1 in the c1500 what all would need to be done? What parts do i need? I have the parts car so i have the computer and original harness any useful information is welcomed thanks in advanced
Re: tbi to lt1
Not 3rd gen related so this thread wont last long
Check out the LT1 swap sticky in the LT1/LSx forum. It covers alot of the basics not necessarily platform specific. Moving on, its externally nearly identical to a classic SBC/700R4 which you likely had start with, so drop it in with your old mounts. Both are return style fuel systems so simple adapter lines cover fuel. Upgrade the in-tank pump, figure out the exhaust and get a harness. Stand alones work great
Those are the major points
Transmission: 4L80E/4L80E
Re: tbi to lt1
As long as the discussion is limited to the LT1 (which can be related to an LT1 swap in a 3rd gen) and doesn't get into details on the truck side, it can stay here.
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Re: tbi to lt1
The throttle body is very similar to the one in the third gens, so it would be like a 92 rs tbi. i have a cut up harness out of a 92 tbi rs that i was going to use for my lt1 swap
Car: 85 Z28
Engine: 93 LT1
Re: tbi to lt1
The throttle body is very similar to the one in the third gens, so it would be like a 92 rs tbi. i have a cut up harness out of a 92 tbi rs that i was going to use for my lt1 swap. You need a bracket for the trans cable that runs to the throttle on the throttle body and the right cable length. Everything else would be the same as a regular lt1 swap
codeysabatini
Nov 10, 2015 04:07 PM
