Cranks but no start
Old Apr 27, 2015 | 08:40 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Transmission: GTO T56
Axle/Gears: 3.73 S60
Cranks but no start
Hey guys,
I'm running the HP EFI system on my lq4 swap. Each night I've been disconnecting the computer wires from the battery because the fuel pump has been kicking on and draining my battery. Today when I reconnected the wires the starter cranked but the engine just would not start. I can hear the fuel pump and injectors prime when I first turn the ignition to on. The fuel pressure sensor is telling me that the pressure at the rail is normal. I read that it could be a cam or crank sensor issue but I am getting an rpm reading when the engine cranks so I don't believe that's the case. The fuse between the battery and relay checked out fine. I also figured since I've been trying to start it a lot today the engine might be flooded. I pulled a spark plug and it was completely dry. It was running great last night so I'm not really sure what would've changed since. Any help would be appreciated. Thanks
Old Apr 27, 2015 | 11:53 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Re: Cranks but no start
As an electronics tech on large jet aircraft I can say that what you've been doing is detrimental to the PCM. You have quite possibly corrupted the software in the computer. These PCMs have a reason they are kept on the hot battery bus on the car. You would be better off to have disconnected the pump relay. Look at it this way, When is the most frequent time you blow a light bulb? When you first energize it. The initial cold load shock (highest current draw) happens on initial start up of any electrical device. I hope you have not damaged your PCM but ya never know. Seems like someone once said on this board (maybe Pocket) that the cam sensor is only used for start up. Could be that, but I would definitely stop de-energizing the PCM and then re-energizing it.
Old Apr 28, 2015 | 12:09 AM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Ok, I'll make sure to stop doing that then. I didn't think it would make a difference as long as the ignition was off and it wasn't drawing power. Thanks for letting me know
Old Apr 28, 2015 | 12:25 AM
92BLKL98's Avatar
Sounds like you have a nice build, I hope you get it running again. I'm just now working on mine.
Old Apr 28, 2015 | 08:06 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Interesting... Another Holley HP with a fuel pump that won't shut off. You're not the first.
Wire red fuel pump power to a switched battery source, not a constant battery source. This is one of multiple areas where the Holley directions should not be followed. In reality there is likely some kind of deeper problem with the Holley logic, or a ground loop issue with the ECM drivers but good luck solving that. You can always talk to Danny at Holley HP forum and see where it leads, but my method is common best practice regardless of what Holley instructions say.
While you're at it get the injectors off constant battery too.
Old Apr 28, 2015 | 08:12 AM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
I'll have to move it to switched power. What I don't understand is why it worked fine for a while and then started acting up again.
Do you have any ideas why the injectors wouldn't pump fuel? There's a possibility I'm not getting spark either, so I'm thinking maybe the relay.
Old Apr 28, 2015 | 08:22 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Check your grounds. Also get a noid light to see if the injectors pulse And see if you're getting spark. Always good to start off with the basics and go from there
Old Apr 28, 2015 | 08:32 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What I am suggesting is not the root of your problem. It is just an improvement that will keep you from being stranded somewhere with dead batteries.
I'm not sure how to help with your current problem other than suggesting you go over to the Holley HP forum and talk with Danny. He is a really smart fellow.
Old Apr 28, 2015 | 11:52 AM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
I had a few minutes to continue looking at it and I noticed the relay has no cover. Actually I don't think it even did when I bought it but it looks like there's some rust coming out the bottom of the relay. I removed it and the contacts seemed fine. When I reconnected it the car it started but died shortly after so I'm thinking that may be the problem.
Old Apr 28, 2015 | 02:47 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Good news, I figured it out. The relay went bad. I was able to open the relay and found that there was a coat of rust over everything. I used a wire brush to clean it off and when I did I noticed that one end of the resistor broke away from the solder. I resoldered the ends of the resistor within the relay and reconnected it. I also relocated the fuse and relay to the inside of the car. Car fired right up.
I think that may have also solved the problem I was having with the fuel pump. I'll continue checking it throughout the day to make sure. If it kicks on again I'll add a switch or tie it into a switched power source.
Thanks again for all the help
Old Apr 28, 2015 | 11:30 PM
92BLKL98's Avatar
Great glad you figured it out and the PCM is OK.
Old Apr 29, 2015 | 04:50 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Glad it was something simple. If I were you I'd keep a spare relay jic it does this again.
Old Apr 29, 2015 | 02:46 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
For anyone else with the holley efi system, I found out today that the main relay in the harness has an optional weatherproof relay. The original relay doesn't have a cover, instead its setup just in case you want to upgrade to the linked weatherproofed relay.
http://www.lsxtune.com/shop/product_...roducts_id/671
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
