tick master ls swap
Old May 5, 2015 | 01:34 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Transmission: GTO T56
Axle/Gears: 3.73 S60
tick master ls swap
I sent my tick master cylinder out to be replaced because fluid was leaking out the boot. A few weeks later my new master cylinder is doing the same thing. Anyone else have this problem?
My t56 has been having clutch issues since I did the swap. My trans grinds into third and fourth and sometimes doesn't lock into second. If I shift at low rpms I don't get any grind and the trans goes right into gear. Its been driving much better since getting the new master but now I notice its leaking again. I think the shifting issue is just air in the hydraulics but I'm not sure if the master needs to be replaced again
Old May 5, 2015 | 02:40 PM
Pocket's Avatar
Car: 91 Trans Am
Re: tick master ls swap
Make sure the pushrod is strait when going into the master. Most 3rd gens require dimpling of the fenderwell to clear the master for this
Old May 6, 2015 | 06:27 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
It looks like my pushrod is on a slight angle but I'm having trouble getting the seam on the fenderwell to dimple in enough to get it straight. How close does it have to be?
formula1lle
Jan 29, 2016 10:56 AM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Sep 4, 2015 07:57 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
