Whats this for?
Old May 8, 2015 | 06:05 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Whats this for?
Not the sensor, but the pigtail.Seems like its just an extension.The harness comes down from the top.Only to have this pigtail run back up.There is nothing between the pigtail connectors.Couldnt I just omit that & plug the harness straight into the sensor?
Old May 9, 2015 | 12:30 AM
Heritage Z's Avatar
Car: 92 Z28
Engine: L76 in the works.....
Axle/Gears: 3:73
Re: Whats this for?
I haven't picked up my cam sensor yet, but it looks like its just a pig tail to route it down and away from the accessories. All of the stock sensors are routed the same way.
Old May 9, 2015 | 01:09 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Whats this for?
That's kinda what I was thinking, but i could probably keep the harness out of the way w/out this.
Old May 9, 2015 | 07:18 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Whats this for?
Theres nothing wrong with ditching the pigtail. Bear in mind the pigtail and sensor use different connectors
Old May 9, 2015 | 10:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Whats this for?
Thanks, Hopefully the harness matches the sensors connector.
