New to this Section- First LS Swap
Old Dec 15, 2015 | 09:04 AM
  #51
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: New to this Section- First LS Swap
Completely worth it for that point alone.
Old Dec 15, 2015 | 09:13 AM
  #52
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Lol, fair enough. Just coming to the point where I'm going to have to STOP spending money pretty soon.
Found a deal on a ac compressor and bracket. So still have to get gas tank, shifter plate, different shifter stick, fuel fittings, harmonic balancer, hoses, belts, push rods, fluids, fuel level sensor, block plugs, a few sensors, stuff for wiring, ls3 coils?, clutch upgrade?, intake upgrade?, valley cover upgrade? and whatever else I'm forgetting..
Old Dec 15, 2015 | 01:44 PM
  #53
R13_Braz's Avatar
Car: 2014 Z28 #80
I understand your pain perfectly, sir. I still have a lot I need to do, but money and other vehicles going boom take my time up. My wife's camaro... my friends Honda... our family van's transmission yesterday.
Still need to get my AC delete box so I can have the blower motor back... need to get my windshield replaced and my headliner redone... need to get my seats finished, get the LS1 tank swapped in, paint etc. lol. I did just enough to get it on the road safely, and tuned (and even that needs to be touched up).
Old Dec 16, 2015 | 03:35 PM
  #54
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, LS3 coils use the same type connector as LS1/LS2/LQ4, etc.
Old Dec 17, 2015 | 07:39 AM
  #55
Car: 92 Z28
Thank you, makes it a little easier. Thought I found as set for $80 and then he sent me a picture of the truck coils.. boo. They have all new sets on the bay for like $130 though, which if I don't need the harness seems like the way to go.
Went ahead and ordered the LS6 valley cover so I can clearance the block before I clean it. Won't need the coils until I'm ready to paint stuff as I think I'm gonna do them body color.
Old Dec 20, 2015 | 07:22 AM
  #56
Pocket's Avatar
Car: 91 Trans Am
Which begs the question... how the hell is it running well? Vacuum is always within range for the cam, oil always comes out looking relatively clean (considering my rings are gapped for boost)... I'm at a loss at how this has worked fine for over 1k miles now without a way for fresh air to get in properly.
Needless to say, I'm going to run a line and see what happens
Pop the valve covers off and look for build up. Increased gap with more blow by would increase build up. Maybe the blow by was acting as your fresh air in? Dunno
Should keep it from sucking up oil too, not sure if worth $90 or not.
The LS3 coils take the same plug right?
The large white inline connector is the same for ALL LSx coils. The small connector going to the coil themselves is split into two types: LS1/6 Fbody/Ybody/GTO/04 CTS-V (pictured on the polished valve cover) vs everything else
Old Dec 28, 2015 | 09:32 AM
  #57
Car: 92 Z28
So the LS3 Coil itself takes a different plug, but if you get the whole set with the harness it plugs right up, correct?
This style below.
Got a little bit done over xmas. Block is completely polished and pretty much ready for assembly. I cleaned up the head gasket area and let the block soak in degreaser along with some other dirty parts and pressure washed them. Started sanding the other stuff down to polish and blew up my air compressor. Vengeance sent me a second wrong cam, LS6 valley showed up and I got the block notched before I PWd it. Letting the pistons soak a day per in Carb bucket and cleaning each one right now. Want to finish poslishing/sanding before I assemble the short block so I don't get metal shavings in it after it's put together.
Old Dec 28, 2015 | 05:28 PM
  #58
Pocket's Avatar
Car: 91 Trans Am
Right. Every common LSx coil set comes with the same inline connector like this. Every OEM harness, plug nearly every aftermarket harness will come with this connector
LS1/6 coils look like this:
And take this unique connector
All other LSx coils use this connector
Old Jan 4, 2016 | 09:22 AM
  #59
Car: 92 Z28
Got it, guess i'll stay on the lookout for a used set then. Thank you Pocket.
Still polishing stuff. Got almost everything but the alt/wp sanded down to 400 to start polishing, will get those done next weekend and hopefully make some progress with polish. Starter is staying as is, and not sure what to do with the PS pump, it is the only steel piece there and the tank is plastic. Will probably paint the pump aluminum or cast iron.
Pistons were pretty coated, I have been soaking them one by one overnight in carb cleaner and then cleaning them up. Almost all the way clean after that but will have to get a little bit of grit out of the ring grooves on a few.
Then soak all the valves and clean em up, start working on heads. Hopefully Vengeance will get me the correct cam I ordered back in November.. Glad I was planning on doing this instead of assembly.
Old Jan 4, 2016 | 07:08 PM
  #60
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Subscribed. Very nice!
Old Jan 5, 2016 | 10:01 AM
  #61
BADNBLK's Avatar
COTM Editor
You are a mad man polishing the entire block and all the aluminum accessories, but... I like it. Its all in the details.
Old Jan 7, 2016 | 05:05 PM
  #62
five7kid's Avatar
Originally Posted by BADNBLK
You are a mad man polishing the entire block and all the aluminum accessories...
You would know something about that, eh?
Old Jan 7, 2016 | 06:22 PM
  #63
BADNBLK's Avatar
COTM Editor
Nah I painted everything on mine, except a few bolts
Old Jan 7, 2016 | 08:43 PM
  #64
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I hope your sealing those polished parts! lol.
Old Jan 8, 2016 | 07:22 AM
  #65
Car: 92 Z28
Thank you for the support, I need it
I knew I would regret the decision when I made it, and I still do. Hopefully the last engine that ever goes in this car, so better do it right.
I will. I need to do some research on what do use. Is Zoop Seal still the best game in town, or has something better come out?
Old Jan 8, 2016 | 08:43 AM
  #66
Car: 87 TA clone
Zoop seal is pretty good. Not much out there that I know of for sealing that lasts. I use a product called "sharkhide". Its good for any surface sealing of any metal/alloy etc. Supposedly has a lifespan of years even on higher temp surfaces like engines etc. I use it on my aftermarket intakes and they look brand new years later... I hate oxidation! I also do it on my aluminum heads, billet anything like brackets/pullies/dampeners, Any aluminum accessories like alternators/waterpumps, valve covers etc.
My newest thing I put it on was my new billet torque storm supercharger. In the process of doing it but got the bracket all sealed i think.
I use it on everything and the 1qt jug has lasted me a few years and I still have like 1/2 left. Its so thin that it doesn't take a lot of cover a large area so even tho its kinda expensive (still less than Zoop seal I think) its a lot of product for your money.
Site
http://www.sharkhide.com/index.html
Pulled from there Q&A
Q: How long will the average application last?
A: On things like Motorcycles, Street Rods, Aircraft and other things that see limited fair weather use, it's not uncommon to get 6 or more years of protection
Old Jan 13, 2016 | 12:04 PM
  #67
five7kid's Avatar
I thought so, was corrected. The LS3 coil harness has the same connector to the PCM as the LS1 harness, but I was told the individual LS3 coils have a different connector.
I have a set of LS3 valve covers and coils that I eventually plan on installing. But, that's probably going to wait until I do other things to the engine/car.
I used an LS6 valley cover on my stroked LQ4. Well worth it, in my opinion. Didn't totally eliminate oil in the intake manifold, but reduced it significantly.
Old Jan 14, 2016 | 07:45 AM
  #68
Car: 92 Z28
Thank you for the follow up. I switched gears and am looking for a used set LS3 coils with harness now instead. I could get new coils for $140, but then adding 8 plugs to that at probably $10-$15 per, no thanks.
Picked up the LS6 valley cover too and notched that ash tray in the block, just need to get the engine together after I finish polishing.
I think I have decided to switch from Kooks to the Holley exhaust system, trying to see if I can get an account number here at work for some kind of discount since I missed out on the holiday pricing.
What do you guys use to clean the valves off? Soaking in carb cleaner doesn't seem to be cutting it at all. Are the roloc cookies ok? I know you don't want to use those on pistons because it removes the hypereutectic coating, what about valves?
Also is there any list of what to apply to what bolts? I realize it is mostly common sense; oil on the internals and blue lock tight on externals for the most part. But a check sheet during assembly wouldn't hurt, I have the torque speck sheet for all the bolts but it doesn't have anything on what to apply to the bolts.
Old Jan 14, 2016 | 08:39 AM
  #69
Car: 87 TA clone
If your going to be changing all the coils I would look for a complete set of the truck coils (the ones with the heat sink coils at the top of each) they are the most powerful of the stock coils... considerably hotter spark than the car versions. Trucks got the best coils and hottest sparks.
Holley system looks super nice... with a big price tag. Im sure either one would perform, fit and look great. Wish I had the money for those setups.
Carb cleaner/sea foam usually does the job. I've used dollar store oven cleaner to eat all the crap off my LS which had 150K on it and years of baked on oil and $hit. That did a great job. Not sure if I would use that on the valves though. Maybe an ultrasonic cleaner? or take them to a machine shop to get hot tanked?
I don't use locktite on much. If your using ARP hardware then all you need is the ARP moly assembly lube. If using OEM hardware then you prob dont need anything but lube if required by OEM. OEM tq to yeild require special tq values. Def Dont put any locktite on the balancer bolt as alot of people snap them in the crank due to that. They use so much tq and have a coating on the underside of the bolt head to help from loosening. I use locktite on flexplate bolts, tq converter bolts for sure. I might use blue locktite on the cam bolts but thats about it.
Old Jan 14, 2016 | 04:28 PM
  #70
Pocket's Avatar
Car: 91 Trans Am
Hit up rockauto and check out LS7 coils. $11ea brand new. Use any truck coil harness, I can build some for you alot cheaper than you expect if you cant find any
Stock TTY head bolts have some lube on the bolts already. Since these have to be replaced after each use, you dont have to worry about this. The crank main cross bolts have RTV on the underside of the heads to seal, not lube. They're listed as one time use bolts, but if you put a dab under the heads they can be reused as many times as youd like. Standard 24lb/ft like all M8 bolts on the LS engine. The crank bolt also has this sealant under the head but is TTY, get a new one
The rest should be standard use anywhere any amount of times bolts. Gaskets are reusable to an extent. Examine the rubber, if its squished flat like the aluminum frame then its trash. If the rubber sticks up and isnt torn, then reuse it. Its not required, but I like to put a dab or RTV at the bottom of the timing and rear covers where the gaskets meet the oil pan. Ive seen minor seepage and its simple to solve. Remember the timing, rear and oil pans all need to be aligned. There are special tools for this but I prefer to let the gasket do what its going to do. Havent had a leak
Loosely bolt all 3 on with gaskets and press the balancer on. Use a 360* bellhousing or strait edge to align oil pan to block and torque to spec. Snug the rear cover bolts to the block, then torque the bottom two from the oil pan. Torque the block bolts. Snug the timing to block bolt then torque the two on the bottom. Torque the last timing cover bolts
Oil pan alignment is based of the BH and everything else needs to be centered off the crank and pulled down to its top edge. The F/R main seals will ensure L/R alignment of the F/R covers. L/R alignment of the pan is not critical
Old Jan 15, 2016 | 07:50 AM
  #71
Car: 92 Z28
Thanks Pocket, that is cheaper than I have seen on the coils. I think I am going to hard wire the coil plugs into the harness like you suggested before. So if I can find cheap plugs it will be worth getting new.
I have all new gaskets, most all were trashed when I removed them so I got everything. I already grabbed Fel Pro head bolts, and a GM crank bolt, and I was debating on getting main cross bolts, some say yes some say no, but if it is just because of the RTV that is an easy fix.
Your oil and timing cover alignment directions help a lot as well. Most of what I had read just said kinda tighten the covers, put the pan on torque it and then torque the covers. I've seen the tools, but too much money if you don't really need them.
And thanks CBB as well. I'm just using the ARP connecting rod bolts and have some of the lube. Would be nice to have a full set, but for what it costs, not worth it on this build.
Old Jan 15, 2016 | 09:03 AM
  #72
Car: 87 TA clone
This is all I could find on the coils. Typing in LS7 coils doesn't net any results on rock auto. AIRTEX / WELLS 5C1555 {#12573190, 1788399, C1512} These go for 10.23 each and are the rounded delphi coil design for a 2014 camaro with a 6.2. These are made my airtex.
Pocket got any part numbers for those coils? are they hotter than the truck coils with the heat sinks? Do the heat sink truck coils take the same plug as the regular square D581 coils do? I'm thinking I might need a coil upgrade in the future with a 10psi supercharged 5.3
Old Jan 15, 2016 | 06:43 PM
  #73
Pocket's Avatar
Car: 91 Trans Am
Ive got more than enough coil connectors to sell. Can leave disassembled or with some wire, your choice
Compare the crossmain bolts to standard cover bolts ie timing. Same thing, just different length and has sealant under the head
Look up a 2010 Corvette 7.0. Very first coil is the airtex round, cant beat that price brand new. Under it is the flat LS3 coils. Both hit very hard, inline or better than the popular heatsink coils
Like I said above, LS1/6 coils pictured take a unique connector. All other LS coils use the same
FWIW, 10psi on a 5.3 wont come close to maxing even the weakest LS coil, so anything you run will be fine
Old Jan 20, 2016 | 07:18 AM
  #74
Car: 92 Z28
Well I guess I'm not switching to the Hooker exhaust since my Kooks showed up without warning yesterday. Guy said for the 4th time it would be two weeks last week and it looks like they shipped out last Tues? Still waiting on the Y pipe tho.
These things are realllly nice though. I've never had headers this nice before.
Also decided to just cheap it out and get an LS6 intake and port the stock throttle body. I wouldn't mind paying for a Fast intake, but after that, fuel rails, TB, MAF and intake it is way over what I want to throw down. I think this car will have more power than I'll ever use anyways.
Old Jan 20, 2016 | 08:34 AM
  #75
Car: 87 TA clone
They look good. Depends how much u paid for them lol. I went with the cheap RI SS full length and I'm happy with them esp for $300 to my door. They are not a work of art on the inside of the collector tho but as long as they don't leak I'm not worried.
They did a intake shootout for all LS intakes on the market recently in one of the big mags, CHP or carcraft. Basically the Truck intake performed better than most till 5500 and basically on par with the LS6. Speed master at only $220 shipped performed alittle better than both in the upper ranges. Then of course all your hi rpm expensive intakes like Holley, fast etc. if u haven't gotten the intake yet and if it's not cheap (everyone with a LS6 intake thinks they are gold for some reason) look into your options.
Old Jan 20, 2016 | 10:47 AM
  #76
Car: 92 Z28
I got about as good a deal on a new set of Kooks you can get, I think. Was going to go with the RI's but then saw a deal on these over the holidays and jumped on it.
LS6 intake should be here tomorrow. That speedmaster is a good bang for your buck on the intake, but then still.. $300 TB and $300 MAF ect.. I'm really going to need new tires and a few other things when I get this done which that money should be going to.
Old Jan 25, 2016 | 07:44 AM
  #77
Car: 92 Z28
Well I couldn't miss Football, but have a lot of work to do still. So I made do lol.
Got all the polishing with Emery finished. Just need to clean them up and finish the rest of the polishing and then coat with something.
I finally bothered opening my LS7 clutch and realized there is a slave cylinder in there? I can't use this can I? It doesn't look like the line will hook up and no clue on spacing ect..
Old Jan 25, 2016 | 07:58 AM
  #78
R13_Braz's Avatar
Car: 2014 Z28 #80
I removed the line from the slave cylinder I got... also removed the fitting. Replaced it with Russel quick-fittings and a 36" line I routed through the cabin to cut down on exposure to heat. Running stock third gen clutch master cyl with it. Also, if you hadn't planned on it yet, get a quick bleeder... trust me, you'll want it.
Old Jan 25, 2016 | 08:55 AM
  #79
Car: 92 Z28
Was it LS7 or LS1? I have an LS1 master, but the line is definitely different. Not sure if the line will link up with this slave or it the slave will work physically. I already got a new LS1 slave so no big deal, but could always take it back and save some monies if I don't need it.
Old Jan 25, 2016 | 03:26 PM
  #80
Car: 92 Z28
Old Jan 26, 2016 | 01:24 PM
  #81
R13_Braz's Avatar
Car: 2014 Z28 #80
Sorry, it was an LS1 slave.
Old Jan 26, 2016 | 06:04 PM
  #82
WTR388's Avatar
Car: 87 Trans Am
I also used the LS7 clutch with LS1 slave, 3rd gen master. I used a stock 4th gen line, I just made the master fit the line, did the "drill mod" on the 4th gen line, routed in "stock" position and it works great, I've had no fade issues due to exhaust heat.
Get a long bleeder line, mine is long enough it reaches the master reservoir, part of my bleed process involved me cracking the line open and leaving it in the reservoir as I pumped the clutch.
Old Jan 27, 2016 | 07:33 AM
  #83
Car: 92 Z28
Yes I know the LS1 slave and master work, curious if the LS7 slave works with block and LS1 T56/master as it is essentially free.
Old Feb 1, 2016 | 08:35 AM
  #84
Car: 92 Z28
Well still no exciting progress. But I am pretty much done with polishing. I'm going to hit them with a soft flappy cotton wheel with White Rouge and then probably some Mothers power metal, but not until I'm ready to seal everything. Otherwise I'll just have to polish them again.
Unknown to me Zoop Seal went out of business like 10 years ago lol. But they have a new company from the same people Shine Seal, which is I guess what I'm going with. Kind of nervous about using something I haven't tested before and I don't think it is a two part mix like the Zoop, but I can't go back in time so this is it.
Next weekend I'm going to start on the heads, port and polish and sand/polish the outsides. Then I can actually start assembling stuff finally. Hopefully I can get the heads done in one weekend, but I kinda doubt it.
Old Feb 8, 2016 | 08:02 AM
  #85
Car: 92 Z28
This weekends work. Finally starting to get to the good stuff. Gasket matched the Ex, removed rocker bolt nub, swirl ramp, and blended both seats and valve guides and smoothed the runners. Need to clean them up a bit, intake is pretty much done, just need to hit the Ex with some higher grit paper. Should be able to finish this up and hopefully get the outside of the heads polished as well (shiny).
Old Feb 15, 2016 | 08:28 AM
  #86
Car: 92 Z28
Not much time this weekend, but finished polishing out the exhaust runners up to 320 grit, sanded the combustion chambers down, cleaned up the valve seats, pulled the freeze plugs, and started sanding the casting off of the outside of the heads to polish them up. Should finish and coat all the polishing next weekend, and hopefully get some traction on the short block assembly. If a miracle happens maybe I can get the heads together as well and mounted to measure for push rods, but I doubt it.
Before sanding
After
P/P finished, cleaned up the seats.
Old Feb 22, 2016 | 01:06 PM
  #87
Car: 92 Z28
Never thought I was going to say this, but I finally finished polishing stuff. Got everything sealed as well, just have to go over it with a coat of polish for the sealant after it cures. I cleaned up the valves too and the Exhaust is really pitted. Was thinking just buy new but I don't see any decent options. The only stock size I see is some Manleys that are like $150 a set, and OE is $30 or so per. I guess I'll try to lap these and if not I might have to have them re cut or buy the Manley valves.
Going to the Sprint cup race next weekend so I'll just have Saturday. Guess I'll try to lap the ex valves and hopefully get the crank blue printed and in the block at least.
Old Feb 29, 2016 | 07:43 AM
  #88
Car: 92 Z28
Wow.. finally doing something other than polishing, feels good!
Exhaust valves still have a tiny bit of pitting, but I think they will seal fine. Did not want to cut into the seat any more.
Got all the valves done and heads assembled
Cylinders honed
New Oil Galley Plugs in, have to find a allen socket big enough for the big one.
New cam bearings are in. The old ones actually had a bit of wear I couldn't see with them in the block so it is good I changed them. New mains in and caps on to check clearances and that is all I got to.
Should be able to finish the short block and measure for push rods next weekend. Then just pop the heads and accessories back on and probably rebuild the trans next.
Old Mar 7, 2016 | 07:47 AM
  #89
Car: 92 Z28
Finished cleaning up pistons, bored guage/Mic'd everything, double checked with plastigauge, covered in assembly lube, indexed piston rings, stretched the ARP bolts, and bolted the bottom end down. I didn't get to measure for rods yet, but it shouldn't take too long. Need to get the cam in too.
Most all of my clearances were .0020 so on the looser end for the mains but still in spec, right in line on the connecting rods, ring gap is right around .020.
Old Mar 14, 2016 | 08:56 AM
  #90
Car: 92 Z28
Well I've hit my first roadblock in the build, as usual self induced. Was measuring for push rods and coming up with 7.30 including .075 pre load which seems way to short. Heads were shaved, but only .018. Tried to clay it with this length using the PR checker and pushing the valve in the clay bent the push rod checker (I guess they are kinda soft to prevent too much damage, makes sense). But doing this I also realized I was checking for length at TDC on the Exhaust stroke instead of Compression so the valves were slightly open already. Double oops
With no checker anymore I tried to utilize the stock 7.4 pushrods and used the old school method of counting turns and got almost 2 full turns. Which I had read last week was .05 per turn, however finding out now that it is more like .07 which matches what I was finding when using the measurer. (This contributed to a lot of wasted time over the weekend going back and forth between the checker and old school not matching up.) Pre load on the LS7 lifters shouldn't be more than .1. So I was at .14 ish with those. Well I clayed it with these anyways since I didn't have anything else to use. And my PTV is way too close. However it looks like I do need to run an undersized rod. Hopefully the right length will give me enough PTV to squeeze by.
But good news I finally remembered to check end play and it is good.
This is what the clay looked like running a solid LS1 lifter with a 7.4 rod. Ex clearance is probably ok, but intake I've got like .03 at max. Hopefully a little shorter PR will yield better results, otherwise I will have to flycut the piston.
Anyway ordered another PR checker which should hopefully be here tomorrow. Then start checking all over again and hope everything comes together.
Old Mar 14, 2016 | 09:04 AM
  #91
Car: 87 TA clone
Stupid question... But are you checking Pushrods length with head gaskets? Lol. Or at least shimming the head to compressed gasket thickness?
Also when checking pushrod length you should be using a low pressure spring... Don't see it in the pics or in the info.
Remember with pushrod length and rocker wear pattern on the valve stem your not looking for the mark to be center on the stem as much as you are looking for the thinnest mark on the stem.
Old Mar 14, 2016 | 10:13 AM
  #92
Car: 92 Z28
Yes I had head gaskets on, though that is a reasonable question considering I was checking from the wrong TDC, lol.
I used the push rod tool with the LS7 lifters which is what I'm going to be running. Unfortunately just with the cam in the wrong spot. Just supposed to find 0 lash and then add in the pre load you need. I just had the cam at the overlap spot instead of on the circle.
And I thought you only marked valves when you are running a roller rocker on a stud? These are just stock rockers with the trunion kit, flat valve contact, pretty big too. I haven't seen anything on marking these to test proper length.
Old Mar 14, 2016 | 10:31 AM
  #93
Car: 87 TA clone
Ah... gotcha. Didnt know you were going to run the OEM rockers. I just threw the 150k back on mine when I swapped the stock springs for new blue LS6 springs. Trunion upgrade is good insurance and will probably do mine as well when I tear the motor apart down the line.
I wonder how your going to check the rocker contact patch since its a flat rocker on a flat stem? If you mess with the pushrod length too much I would suspect cocking of the rocker surface against the stem causing wear issues and lots of friction. How are you checking preload with the OEM rockers lol? Arent they just a bolt down... theres no preload nut. unless this is due to the LS7 lifters... which Im not sure if they are different than stock in length.
Why Dont you just deduce the amount you removed from the heads or whatever and subtract that from the OEM pushrod length. Throw in a tool for the heads and flycut the pistons. You said you took off .018 off the head... so for ***** and giggles 7.4" - .018" = 7.382" Since the pushrods are parallel to the head/stems right? Maybe compensate for difference in head gasket thickness if you running different than stock. But I'm sure the large contact patch of the OEM rockers allows for large fluctuations in tolerances from the factory.
Sorry, I'm rather new to the LS motors. I assumed you were running aftermarket rockers since your trying to adjust preload which shouldnt be possible with the OEM setup.
Old Mar 14, 2016 | 12:14 PM
  #94
Car: 92 Z28
You just measure 0 lash and then add in what your pre load needs to be to the push rod length. It is not adjustable, which is why you have to measure the PRs. In my case where I was checking (in the wrong spot) 0 lash was about 7.225, so add in .075 pre load and you run a 7.3 rod. Unfortunately calculating it is not that easy, bigger cam, milled heads, thinner head gaskets, valve job, ect.. Just dropping the head mil and gasket I should be down .032, but a lot of times bigger lift cams have to use a smaller circle as well. Only way to know for sure is to measure.
I might be wrong but I think since the rockers are pedestal mounted instead of stud mounted you don't need to worry about the contact pattern. The pre load goes on the lifter so the rocker to valve contact stays in the same spot when you are on the circle of the cam.
As far as fly cutting the pistons, I would prefer not to. But I'm going to measure and then block it again and do what needs to be done. Even if I do have to cut them, I need to figure out how much. Using just the gasket and mil difference assuming I run a stock length rod that is only cutting .032, but my PTV checked down to .03 with those rods. So even with a cut I'm still at .062 and should be at about .1. Gotta measure and clay it again
This is a pretty good vid, but he is off on his measurments for a turn on the rocker stud, it is more like .07 and change than .05 per turn.
Old Mar 15, 2016 | 08:50 AM
  #95
Car: 92 Z28
Bunch of parts that have showed up recently. Stuff for fuel hook up, PS pulley, coils, ss bolts for the coils, generic shifter boot, trans bleeder line, got some 3rd gen pedals too since they are supposed to be better, got the harmonic balancer and all my poly mounts as well. Just need tank, push rods, hoses, and then stuff for AC, Heater, and wiring and I should be good.
Would have liked to paint everything that was getting paint body color, but the car will be driven and I decided to to do spray can on stuff that will need to be touched up. So PW pulley, stater, PS pump done, will do the k member and all my suspension stuff in this color as well. It is a metallic dark grey, should match the car color and polished stuff well. You can see it on the water pump pulley here, along with my helper.
Old Mar 15, 2016 | 09:12 AM
  #96
Car: 87 TA clone
Hmmm parts! I love getting boxes of parts. It's like xmass everytime!
Nice color! As it's the exact color of my car lol I shot it with $250 worth of summit dark charcoal metallic grey including the clear and sealer etc and found a dupicolor can that's the exact same color! So I use that on painting the ECM and other things that isn't worth breaking out the paint gun.
Old Mar 15, 2016 | 09:39 AM
  #97
Car: 92 Z28
I bought a bunch of Cast Iron paint thinking it would be the right color, but it was way too gold. Had to go grab like 4 cans of what looked close to what I wanted and picked the best one. It is "wheel paint" so hopefully it is a pretty durable for the undercarriage. Will probably still do the trans in aluminum paint.
Old Mar 15, 2016 | 09:45 AM
  #98
Car: 87 TA clone
Yea the dupicolor that I got is also wheel paint. I will say its not as tough as you would think. I painted my valve covers with it and I cleaned everything with brake cleaner before even though the valve covers where pretty dirty they came out pretty good. but the coil covers rubbed alittle and now the paint is flaking alittle.
Old Mar 15, 2016 | 10:21 AM
  #99
Ikes 91Z's Avatar
How did you polish and strip the fuel rails? I haven't seen a good write up on the process and I am needing to freshen mine up.
Old Mar 15, 2016 | 10:28 AM
  #100
Car: 92 Z28
I tried a few different strippers and nothing seemed to take that paint or powder coat or whatever it is off. Ended up just sanding it off, though a soft wire brush might get in the cracks a little better. Then just polish like everything else - sand to 400 wet, then Emery, Tripoli, White Rouge on a buffer wheel/felt bob.
