Temperature Gauge Options for Third Gen LS1 Conversion
Car: 2001 Firehawk, `86 Trans Am project
Engine: LS1 in both
Transmission: T56 six speed in both
I need to install a temperature gauge in my third gen, which now has a `99 Ls1 in it. I have the 2 lead sensor/sender coming out of the side of the drivers side head. I have seen other threads on adding an aftermarket temperature gauge, but I would really like to avoid drilling and tapping anywhere into the engine if possible. My only requirement for the gauge would be that it fits into my pillar gauge pod. Ideas?
Thanks.
Thanks.
Transmission: 4L80E/4L80E
This fits in the LS1 head:
http://www.summitracing.com/parts/atm-2277
Put it in the head opposite the one that has the PCM sensor in it.
Then just make sure the temp gauge you get has 1/8" NPT threads on the sender. Auto Meter has several choices that meet that requirement.
Car: '89 Firebird
Engine: 7.0L
Re: Temperature Gauge Options for Third Gen LS1 Conversion
Use a coolant temp sensor from a '98 LS1 Camaro. It retains the two pins you have today for the engine ECM, but has an additional 3rd pin that will drive your temp gauge. You can rob one of the unused electrical plugs from the EVAP portion of the LS1 engine harness, or buy a repair pigtail for a '98 Camaro temp sensor. I robbed the connector from the existing LS1 harness (see below).
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
http://www.aeroforcetech.com/products_interceptor.html
So long as you have an obd port, these are freaking awesome, monitor anything you need for the engine so long as the ecu can read it.
the_nikfive
Exterior Parts Wanted
Feb 1, 2016 02:52 PM
Linson
Jan 22, 2016 03:47 PM
