Carbed LSX 454
Old Mar 16, 2016 | 05:45 PM
BeyondZ28_85's Avatar
Car: 85 Camaro Z28
Engine: 400 SBC .040 over bore
Transmission: TH350 (TH400 on the way)
Carbed LSX 454
So I think I want to put an LSX 454 long block with Holley tunnel ram and twin Holley 450 cfm carbs on top into my 85 Camaro at some point in the future. The plan is to build the car up with a carbed 408 sbc to a 427 sbc then do the LS swap to the carbed 454. I know my Holley black fuel pump will meet the needs of both applications as will my cooling system. So I'm also building the car so it's pretty much a direct swap into the ready car. So all I need is an MSD or other electronic ignition box to keep timing dead on. Engine mounts. Headers. Correct torque converter and flywheel for LSX 454 to TH400 (full manual valve body without passing gear kickdown or vacuum and maybe a transbrake.) I might also go with one of the MSD boxes that has 8 plug leads coming off it instead of coil packs. Anything else anyone see I should plan for in the future.
Old Mar 16, 2016 | 05:53 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Carbed LSX 454
Standing on the outside looking in, I have to say that 3-step process sounds like a bizarre plan.
Old Mar 16, 2016 | 06:10 PM
Car: 85 Camaro Z28
Re: Carbed LSX 454
I plan to go to the track and let the car make some of its own money and have other vehicles into which I can put each previous engine. I have so many small block Chevys around that I can use my old parts in or on as well. My current stock 2.02/1.60 ported heads will ultimately go on a truck with the Torker II intake and vacuum secondary Holley 750. That motor is a stock bore 400 with a crane fireball 2 cam and Harland Sharp 1.5 full roller rockers and 1.94/1.60 valves. I'll swap my Howards rockers over to my new heads and swap my heads over to the 400 using its Harland Sharps rockers and accessories. So yeah I've got too many sbc to play with if that's possible, haha. I want to try an LS build and I want to do it big with around 700 NA horsepower. The beauty is it'll pretty much be a direct swap motor when the time comes.
Old Mar 16, 2016 | 06:34 PM
Car: 85 Camaro Z28
Re: Carbed LSX 454
So does anyone have a part # for the ignition harness for an LS motor? I'm actually getting into how much to budget for this build so I can start piecing it together again.
2012sergen11
Apr 25, 2016 02:55 PM
Jaysome
Feb 20, 2016 04:11 PM
camaroz1979
Feb 17, 2016 10:50 PM
mcgarnicle
Exterior Parts for Sale
Feb 17, 2016 04:02 PM
jshaf00
Carburetors
Feb 16, 2016 07:09 PM
