LS1 swap Harness, factory TPI inter changeability
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
I recently sold my C6 Corvette, leaning towards picking up a nice Formula for an LS1 swap. My question related in regard to the engine harness, I've read on here there were several harness' which is understandable due to the myraid of different engine combinations. If I was to pre plan and begin the collection of parts prior to getting the car to avoid down time, what years factory TPI harness would I need to integrate in to the LS1 harness? Leaning towards a 91-92 car. So if I were to buy a factory harness prior, to begin building the LS1 based swap harness, would any 90-92 TPI harness serve the purpose?
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Re: LS1 swap Harness, factory TPI inter changeability
Harness needs to match the car. 90-92 will be the same with the exclusion that TPI and TBI are different and auto/manual are different as well. This thread should tell you most of what you need to know.
https://www.thirdgen.org/forums/ltx-...formation.html
There really isn't a ton that hooks up to the thirdgen harness as you can see below. There is a bit of extra work setting up coolant fan and fuel pump relays, VSS, and some extra stuff if changing from auto to manual etc.. Read through the stickies.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If you have a 90-92 TPI harness, sell it and put that towards a conversion harness or making your own out of a TBI harness since you don't need much of it anyway.
I am working on making my own conversion harness from scratch right now, well in the near future. I have all the stuff, just have to get the engine in the car
You can use any 90-92 donor harness, V6, TBI, TPI. That part of the harness that makes it TPI etc is removed entirely
Or just buy a pre-made harness in whole or part
jeremy iroc z28
Jun 28, 2016 12:19 PM
jeremy iroc z28
Jun 24, 2016 07:51 PM
cnuno123
Jun 10, 2016 03:02 PM
jeremy iroc z28
Jun 7, 2016 04:05 PM
[For Sale] SOLD...Stock ls1 heads and valve covers.
redmaroz
LSX and LTX Parts
May 31, 2016 07:07 PM
