DONOR CAR
Old Mar 12, 2017 | 08:55 PM
TUCK1975's Avatar
Car: 1992 firebird vert
Engine: 355 soon to be a 406
Transmission: 700r4 goin t5 then t56
Axle/Gears: 373 or 410
DONOR CAR
Getting ready to start my swap just wondering what i can use from my donor car its a2000 z28 running and driving car or if there is a thread with this kind of info
thanks for any replies
Old Mar 13, 2017 | 10:37 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: DONOR CAR
Your going to get many people telling this as your answers will be well documented in these forums..use the search button and read the stickies!
But to put it simply..swap pretty much everything.
Engine/transmission/driveshaft/rearend
Engine/trans harness and ecu
Front brakes after modifying the 3rdgen spindles
Gas tank
Interior: dash/seats/steatbelts..some have done full 4thgen a/c swap also with firewall modifications
Get a pen and paper..read the stickies and make a list of the swap parts you need and then..start swapping parts. When you get far enough into the swap..then start asking specific questions.Even then..I promise the answer is already on here if you research a little further so dive in.
Old Mar 18, 2017 | 07:29 AM
MustangEater82's Avatar
Re: DONOR CAR
I am doing a 2000 z28 to a 85 z28. I did....
4th gen tank and lines
Harness
Brakes, rear, torque arm
T56
Motor and mounts
Radiator( I am mocking up) haven't DE idea which rad I will use
Coolant resovour, washer fluid tank.
I am using brake booster and master
Pedals, all hydraulics
Seats
There is more...
