Least Expensive LS Swap Oil Pan???
Old Apr 22, 2017 | 06:51 PM
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
Seems like everyone says the 98-02 f-body pan costs the least and doesn't have clearance issues. Does this apply to non OEM pans as well? Others I found:
Spectra GMP77A
Dorman 264-331 Dorman 264-331
In THIS listing it has a bunch more part numbers as well. I know the H8 pan doesn't work.
Old Apr 23, 2017 | 11:57 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Re: Least Expensive LS Swap Oil Pan???
Both of those are the Fbdoy oil pan. But that isnt much cheaper than an OEM one
Old Apr 23, 2017 | 12:28 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Yeah I figure they fit fine, but idk about the quality.
Old Apr 24, 2017 | 01:19 PM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
So on LS motors, the oil pan is part of the structural integrity of the block. Personally, that is somewhere I would spend a little more and get a GM part. Its not something you want to replace later.
Old Apr 26, 2017 | 01:00 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
the Fbody pan and kit is the cheapest you'll find for this. Dont' skimp. I went with the MAST set up for about $500...we'll see how it compares once I get it in the car.
Old Apr 28, 2017 | 11:36 AM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
So I found the
 Holley 302-2 pan Holley 302-2 pan
for a decent price ($294.39 Amazon Prime). After adding the dipstick, dipstick tube and gasket, it comes out to about $40 more than all the oem f-body stuff. I'm sticking with the oem because I need to save some money. If anyone wants the other part numbers or links let me know.
