Dfco/Clutch anticipation switch?
Old Apr 25, 2017 | 06:47 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Question for those of you with a ls/t56 combo. Are you able to use dfco without having the clutch anticipation switch wired in? Ive tried digging around tech and hptuners but havent found a definite answer.
Thanks,
Jay
Old Apr 29, 2017 | 10:08 AM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Re: Dfco/Clutch anticipation switch?
in case anyone else is curious about this in the future, the switch is not needed. If engine has a larger cam map entry and exit need adjusted. You may also have to adjust other parameters of it, but it is usable without the switch.
