which intake for 4.8 build
Old Aug 13, 2017 | 12:55 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
I am in the process of building a 4.8 cammed for midrange power with 6k redline, prc stage 2.5 heads,36# injectors, built 4160e, factory 3:42 gears all in 86 Camaro.
I'm stuck with choosing the factory 4.8 truck intake vs ls6 intake vs fast intake. Which intake would be best for application?
I also plan to get a 6.0 shortblock later on down the line and swap everything over ....
Old Aug 14, 2017 | 11:50 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: which intake for 4.8 build
What are your power goals for each engine? N/A or boosted? The truck intakes provide great power per dollar spent but all OEM intakes will be limited in one way or the other. If your power goals are modest, and your budget equally as modest, a newer truck intake is the best bang for the buck. The 6.0 on the other hand has many options, all depending on what power levels you are looking at (and head style, square vs cathedral).
Old Aug 14, 2017 | 12:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Truck intake with that low rpm range
Old Aug 14, 2017 | 07:17 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
no boost no spray. 400+ flywheel power, this will not be a daily driver but want to have some street fun and take occasional road trips
Old Aug 14, 2017 | 07:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The truck intake (2008 to 2013) will be perfect for that. If you have hood clearance issues, an LS2 intake would fit the bill as well. That's a reasonable goal for a 4.8.
Old Aug 14, 2017 | 07:45 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
I have my 2003 truck intake that came with the engine i wanted to use since i already have it
