03' 4.8/4L60E swap- k memeber ,cross member
Old Aug 26, 2017 | 10:38 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Hey guys.
How did you guys/gals get your ls engine (4.8/5.3 in particular) to fit in your factory k member, cross member?
I was told that I could use the hooker crossmember , adapter plate, and engine mounts, but If i use the factory ls1 oil pan I would need to notch the factory k member
Has anyone ran into this?
Old Aug 27, 2017 | 09:05 AM
toddoky's Avatar
Re: 03' 4.8/4L60E swap- k memeber ,cross member
I see you're a member here also, that will help you for sure with your swap. Members Linson and BADNBLK have both used the Hooker mounts with the LS1 pan, so you may want to send them a PM to get an idea as to the difficulty of the K-member notching required to clear the pan.
Old Aug 27, 2017 | 11:23 AM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Thanks for the info, I just pm them....
Old Aug 28, 2017 | 07:07 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I used the hawks/spohn mounts and have attached a picture of my k-member notched for the oil pan and AC compressor. You don't have to notch it quite as deep as I did but it makes it a little easier to drop the engine in with extra clearance.
Attached Thumbnails 03' 4.8/4L60E swap- k memeber ,cross member-dsc06798.jpg
Old Aug 29, 2017 | 07:10 AM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Ok, thanks for the pic as I am about to do the same install
