Need 383 LT1 build list and HP/TQ numbers.
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
I am going to build a 383 LT1 but I need to see some different builds you all have done. Mostly just concerned with compression and cam combinations. I need to be-able to run 91 octane because its a daily, but want the max HP on pump gas naturally aspirated. I will be running the stock aluminum heads ( 68 cc ported and polished of course). Let me see what you guys are pushing for numbers, cams and compression ratios. Thanks.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Need 383 LT1 build list and HP/TQ numbers.
Advanced induction or lloyd elliott for a cam. Depending how well ported, 226-230 deg on intake lobe. Mid .500 lift
Flat top 11:1 is where i'd stay on 91 even being reversed cooled
These get up around 400 whp fairly easily. Solid mid 11 sec car
Car: 1990 RS Camaro
sweet thanks for the input! Is everyone tending to stay away from Crane Cams? I have always had good luck with them but I am open to suggestions for sure.
