What accessory Drive System with with a Gen 5 Camaro Magnuson Super charger
Old Nov 10, 2017 | 09:34 AM
cobb's Avatar
Car: 90 camaro
Good Morning Guys, I am trying to purchase the correct parts and I am having a hard time. I have a ls3 and I need to purchase all the front accessory's and be able to run a Magnuson super charger. I will cut the K member and run ac.
Old Nov 10, 2017 | 11:40 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: What accessory Drive System with with a Gen 5 Camaro Magnuson Super charger
Call McMillan Speed & Fabrication
http://www.speedandfab.com/
They are the largest Magnuson dealer and know all the parts and combos possible. Even Magnuson tech line will point you at McMillan to get the answers.
Then you need to cross-check with folks here if the accessory drive will fit in the car chassis.
Old Nov 10, 2017 | 11:56 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
The kits for the LS3 Camaro all look to use stock Camaro accessory's and uses one belt to run it all.
