95 LT1 intake question
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
I'm doing an engine swap, 95 LT1 into an 83 Camaro, and I can't account for one threaded hole in the front of the intake pictured below:
I'm pointing at it with a small extension.
Is it for a sensor, if so, which one? Thanks guys.
Transmission: T-5, TH350, T-5
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: 95 LT1 intake question
Massive vacuum leak if you don't at least plug it.
Thanks guys for the info. I found the pipe and hoses and it is for the PCV system. Now all I need is the nipple that goes into the intake.
The nipples that are used in the intake manifold are they pipe threads?
it just breaths naturally.
