Is the walbro-knock off I keep hearing about?
What's this census on one of these gems? Is the walbro-knock off I keep hearing about? Seems legit.
Perhaps not this model, but this brand. I have it saved on my cell phone / ebay app, but cannot pull up the same on a desk top computer.
https://www.ebay.com/itm/KEMSO-340LP...NYX4uA&vxp=mtr
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Is the walbro-knock off I keep hearing about?
Most are junk & fail in a short period of time.
Also a 340lph is overkill for applications under 550rwhp & they draw a ton of current that can overload the factory wiring/connectors in the fuel module.
The connector in a 3rd gen tank is rated for 13A & most 340's draw 17A or more.
Fuel & melted wiring are not a good combination.
For as much grief you go through to swap a pump in one of these cars, I would only use a proven quality pump.
Thanks Lonnie. I hear that! I looked up at Rock Auto and seems like I could get a GMC Syclone/Typhoon Fuel pump for about the same $30.00. Plus its upgrade and the same plugs/wires as the OEM F body.
I'll pass on the ebay gig.
Hi there.
Is it possible to get the product number at Rockauto and also what regulator i should use on my ls3 swap in my Iroc z28.
The regulator should be possible to adjust from the tuning program.
Thanks Hans
Thanks Hans
IH8Fords
Sep 9, 2024 05:39 PM
9D1BURD
Sep 21, 2006 08:35 AM
Firebat
May 11, 2006 02:10 PM
