catch cans-LS
Old Jul 13, 2018 | 08:16 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
catch cans-LS
post em up, I think its time for one. Im getting a strong smell of crankcase vapors and Ive got a closed system, must be venting out of the cap?
Old Jul 15, 2018 | 01:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: catch cans-LS
Are you at least running the stock PCV? I am going to run a mighty mouse system but there are plenty of good ones out there (mishimoto, elite engineer)
Old Jul 17, 2018 | 09:44 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Re: catch cans-LS
Yeah, it's a ls6 setup
Old Jul 18, 2018 | 09:24 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: catch cans-LS
yup
Old Jul 21, 2018 | 08:53 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: catch cans-LS
I run dual MMS cans now,great craftsmanship and does a fine job of catching vapors etc.I drain them once a month basically as the vapors turn into a nasty sludge on the bottom. A proper single can should be all you need with decent size lines.
Old Jul 24, 2018 | 11:39 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: catch cans-LS
i run a universal moroso oil/air seperator from the driver valve cover PCV valve, out of the seperator is a McCaster Carr check valve that goes to the top of the intake. The pass side valve cover goes to a JAZ tiny oil catch can with filter.
It operates like a stock PCV, but it seperates the oil from the vapor before going to the intake. WHen in BOOST the check valve closes before the oil/air seperator and any pressurized crankcase gases will push out of the pass valve cover into the vented catch can. when its working normally, the engine consumes vapor via the driver valve cover and the pass side sucks in fresh filtered air. Couple of years like this, but limited miles (prob 2k) and I empty whatever collects in the oil/air seperator when i feel like it.
3833rdGen
May 15, 2012 10:09 PM
89FRMLA350
Aug 8, 2010 03:45 AM
BlackMagic
Mar 28, 2005 10:48 AM
BlackMagic
Mar 1, 2005 10:05 PM
Kandied91z
Sep 3, 2004 02:55 AM
