TQ install/6L80E or any other full bell housing trans
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
So how are you to bolt and tighten the TQ converter to the flywheel? Is there enough access room through the two inch diameter access panel/hole cover to bolt and tighten the converter to the flywheel?
Doing an LS3/6L80E into my '91 and not sure how this works. Any info is appreciated and TQ recommendations appreciated
Roy
Roy
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: TQ install/6L80E or any other full bell housing trans
Loctite and torque to 45 ft. lbs.
And BTW, this is all done from using Google.
Car: 91 RS
Thanks Pocket, and yes my dumb a _ _ figured that out
Roy
Roy
pentiuman
Oct 11, 2019 09:47 AM
Paul Riccioli Jr
Aug 8, 2005 10:44 AM
