4.8L FLYWHEEL MATED TO TH350 CONVERTER
Old Feb 21, 2008 | 10:52 AM
vorteccrawler's Avatar
I need help. I have a 2007 4.8L Vortec, and my torque converter will not bolt to the flywheel. Any help with part numbers for a flywheel that will work, with a TH350 transmission and the 4.8L would be much appreciated. All suggestions are welcome. Thanks in advance for your help.
Old Feb 21, 2008 | 02:06 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 4.8L FLYWHEEL MATED TO TH350 CONVERTER
http://www.jegs.com/p/J+W+Performanc...10002/-1/10537
Old Feb 21, 2008 | 03:41 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The torque converter should bolt to the flexplate, however the spacing is not right and there is an adapter made to move the flexplate out to where it will bolt to the torque converter.
Old Feb 21, 2008 | 03:44 PM
I tried to bolt the converter up last night, and the center to center spacing on the 4.8 flex plate is approximately 10.5". The spacing on the converter is 10.0". They don't match. Are you saying that there is a spacer that goes between the crank and the flexplate?
Old Feb 21, 2008 | 04:55 PM
I found the adapter kit from Advanced Adapters. Thanks for all the good info.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
PurelyPMD
May 5, 2016 04:57 PM
89newfun
Sep 16, 2015 09:28 AM
Nick McCardle
Sep 10, 2015 08:36 PM
