LQ9 Air Box Options
Old Jan 3, 2021 | 09:47 AM
nicholasktu's Avatar
LQ9 Air Box Options
I'm putting a rebuilt (like new) LQ9 in 1983 Z28, full dual exhaust, trailblazer SS intake manifold, 92mm throttle body, Comp 54-412-11 cam. I want to use the TPI air box because I like the design, but will it flow enough or should I build a larger custom intake? I am also considering the Ram Air system from Hawks but it only works with the Ram Air hood which I can't find.
Old Jan 3, 2021 | 12:27 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: LQ9 Air Box Options
The stock air box will not flow enough to support the full potential of the engine. If you look here Chad Spier(?) took a stock dual Camaro intake and modified it to allow more air flow
You should look in the LTx LSx subforum too
Old Jan 4, 2021 | 09:06 PM
I guess I'll build a custom intake, probably build a cold air box behind the right headlight.
Old Jan 4, 2021 | 10:33 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Try this: I'm not the first guy to do this, and it seems to work well.
jon89
Exterior Parts Wanted
Nov 9, 2009 06:32 PM
irocz eric
Oct 29, 2003 11:29 AM
86FyrBrd
Aftermarket Product Review
Dec 26, 2001 02:39 AM
