Question about 4L60E transplant
Old Mar 4, 2021 | 03:49 PM
NCFarmLife's Avatar
Car: 91 Z28, Black and Grey, T-Top
Engine: 5.3L LS-Swapped
Hi guys... I have a 5.3L from a '03 Suburban that I swapped into my '91 Z28 and is running great. Looking to get the transmission mated up now - I found a 4L60E from a '97 Firebird (RPO code M30) and I'm just wondering if this will connect up with no (or minimal) problems to this engine.
Can anyone confirm?
Old Mar 4, 2021 | 08:10 PM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
Re: Question about 4L60E transplant
97 won't mate up properly. It's going to need an adaptor or the flex plate with the adaptor built in. I think anyways. I assuming the crank flange for the flex plate bolts on the LT1 are the same as a regular SBC. The LS is more recessed thus requiring the the adaptor.
I'm not a 100% sure on this as this is all information I've read online.
[Edit] Recessed isn't what I mean. The flange is flush with the block on the LS
Old Mar 5, 2021 | 06:14 AM
NCFarmLife's Avatar
I cross-posted over to LS1Tech because I needed an answer quick and you are correct. They wont mate up exactly, but it looks like a flexplate with the adapter flange will make everything work.
I think I'm probably good to go then. I'm going to try to pick this up and hopefully all goes well.
UNCLE TOM
May 18, 2010 01:01 PM
smokd u2
Aug 15, 2008 10:34 PM
RebelGQ
Jan 27, 2007 01:25 AM
Team FTS
Dec 14, 2001 01:39 PM
