LS Swap Gauges in 82-84 Camaro
Old May 21, 2021 | 10:53 AM
Trask Hensley's Avatar
Car: 1984 Camaro Z28
Engine: 5.3
i have an 84 Z28 im LS Swapping with a 2002 5.3 and keeping my 700r4 (its built) question is mainly my speedo but all around i'm curious about how to get all my gauges working. i am seeing many confusing things i see Cable X here and there then i thought about it. Would my speedo still work due to the fact im using the exact same transmission? it is a later model 30 spline trans it has a speed sensor but it was in the car before i tore it apart am i fine to just plug it back in and run it? also how do i get Oil Pressure and RPM? also apologies if this is in the wrong area its my first post ever on TGO
Old May 21, 2021 | 09:23 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: LS Swap Gauges in 82-84 Camaro
https://www.thirdgen.org/forums/ltx-...1-harness.html
https://berlinetta.info/C207.htm
Old May 22, 2021 | 11:26 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Ls1 single wire oil pressure sensor will read close enough on stock gauge. Tach output from ls factory ecm is a white wire and can connect directly to factory tach but when programming ecm put tach setting on 3 to register 8cyl. output correctly. I had to use a 10k resistor between the tach wire and an ignition wire to get my tach to work. Apparently the signal is too strong and needs to be bled down with some tachs. Im using 87 gauge cluster so yours may not need that.
Old Jul 28, 2021 | 11:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Actually it's the other way around. The signal is too weak so you need to add a little DC voltage to it to drive the tach.
V1nom
May 30, 2015 12:08 PM
Kuwait_Iroc
Carburetors
Apr 13, 2014 07:39 PM
84 'maro
Aftermarket Product Review
Mar 7, 2012 02:44 AM
TraviZ
Aug 4, 2004 05:52 PM
