92 Camaro 6.0 & 4l60e swap!. Help please!!
Old Mar 16, 2023 | 04:35 PM
Mauro92's Avatar
What’s up everyone I’m new here and I just need help because everyone else in the world seems not to know either.
I’m doing a 2006 6.0 ls & 4l60e swap on my 92 camaro. My question is what TORQUE CONVERTER do I need to use for the combination?? Please lmk!
I know I need the spacer and flex plate already fyi.
Old Mar 17, 2023 | 07:11 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 92 Camaro 6.0 & 4l60e swap!. Help please!!
What mods does the 6.0 have? If stock you just need a factory or factory equivalent unit. If you have a cam you'll want to spec the converter that works best with the cam chosen.
Old Mar 17, 2023 | 09:31 AM
Mauro92's Avatar
It’s all stock! The original setup is 6.0 & 4l80e. But I’m using a 4l60e since that’s what I have and don’t want to switch up. So that’s why I’m asking! So will it still be the same thing you said?
Old Mar 17, 2023 | 09:49 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
if its all stock , the factory converter will be just fine.
Old Mar 17, 2023 | 10:10 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't think the torque converter from a 4L80E is interchangeable to a 4L60E.
Old Mar 17, 2023 | 11:32 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Correct. I didn't realize you were looking to swap converters. In that case, I'd look for an aftermarket stock replacement for the trans you will be using.
Old Mar 17, 2023 | 03:22 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Seems a shame to go through all the effort of an LS swap and leave a stock camshaft and stock torque converter in it.....
​​Huge difference in performance with almost no change in drivability. And it's so eeeeeeasy with the engine out. Get a professional tune when you're done and the car will be quick!
Eric Brown
Feb 17, 2021 02:55 PM
Seth Baggstrom
Dec 7, 2016 12:32 PM
