What intake fits stock Pontiac hood?
Old Mar 16, 2025 | 02:16 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
1991 GTA, need to know what intake fits with zero modification?
BTR Equalizer ?
BTR Trinity ?
Holley Low Ram ?
...is there any others?
Finally, which intake would you chose, both NA and forced induction.
Old Mar 17, 2025 | 10:06 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: What intake fits stock Pontiac hood?
What head port type? You shouldn't have any issues with the OEM/fast polymer style. K-member and motor mounts do however play a big factor. Units like the BMR raise the engine up a bit making things more difficult.
Old Mar 17, 2025 | 03:13 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
What head port type? .
head port should not make the intake higher.
not looking for the everyone has this style intake for mine.
Old Mar 17, 2025 | 03:33 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Correct, unless you have a set of aftermarket heads with a thicker deck. Also, some intake manifolds support more power before they become a restriction, (LS1 vs LS3). What is your motor combo going to be?
Not sure what you mean. Match the intake to the power level and driving style (drag only vs street).
Old Mar 17, 2025 | 04:50 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Unless you're running 500+ HP, an LS6 intake will be all you will ever need.
Old Mar 17, 2025 | 05:00 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Which style head? That will change answers.
LS1 cathedral port
LS3 rectangle port
LS7 rectangle port
In general, car intakes fit and taller truck intakes do not fit.
Old Mar 18, 2025 | 06:51 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Not sure what you mean. .
Thanks for the comments.
So from what i have researched, there isn't a thread/post/sticky on this forum of what intake manifolds fit without modification to hood or cowl.
Head type, port type, hp range, that is all irrelevant for the most part. Will a holley mid rise intake fit?
Will an MSD atomic intake fit?
Will a $4500 'low pro' full billet intake fit?
Or how about a Nelson Alien intake?
-see where im going with this?
yes everyone knows an LS1/6 intake will fit everything, even a 1985 yugo. But that isnt really the question at hand.
The closest thing i have found is some really outdated 'ls swap' pictures in that section of this forum.
Old Mar 18, 2025 | 06:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Head type and engine cradle/mounts very much matter. An OEM head is different than a stock one by enough to cause issues. Same with k members and mounts. Knowing more about your combo will yield better advice. Without this basic info it's just a guess.
Old Mar 18, 2025 | 09:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
No, we can't read your mind. You're feeding us information at a slow drip.
And then you're resisting us when we ask questions.
Be as specific as possible when you ask people for help. Generic questions without bounds get useless answers.
go_topless
Alternative Port EFI Intakes
Dec 1, 2024 01:35 PM
85Z28NOS
Oct 5, 2024 03:36 PM
79TPI
Jul 24, 2022 05:24 PM
Tuned Performance
Aug 18, 2020 06:19 PM
