my new chrome z06 wheels
Old Feb 8, 2008 | 06:16 PM
White25thZ28's Avatar
Car: 92 Z28 Camaro
Axle/Gears: 3.73 posi
There 18x10.5 in the rear and 17x9.5 in the front really changed the look of my car i was amazed.. feel free to post your thoughts
Old Feb 8, 2008 | 08:06 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: my new chrome z06 wheels
Wheels looks nice. Im not into staggered wheels much. Definately needs a drop tho! Keep up the good work!
Old Feb 8, 2008 | 08:13 PM
bj350hp's Avatar
Car: 1987 Camaro SC
out of all the 4th Gen F-body / Vett Rims the new Z06 wheels are the best on thirdgens.
Very nice bro.
(hmm I can't wait till they start making 08+ ZR1 Knock off wheels. )
Old Feb 8, 2008 | 08:40 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
definitely needs a drop a bit, looks like a 4x4
Old Feb 8, 2008 | 09:36 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Pics?
Old Feb 10, 2008 | 05:22 PM
TMZIrocZ350's Avatar
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
I have same wheels. Mine are 18's all the way around though.
Old Feb 11, 2008 | 12:20 AM
Mushmouth_'s Avatar
I like it the way it is, chevy ridin high
Old Feb 11, 2008 | 12:31 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
rims look good , i personly like a lip on my rims
Old Feb 11, 2008 | 09:14 AM
Demon355's Avatar
Both cars look nice, but desperately need to be lowered.
Old Feb 21, 2008 | 10:31 PM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
18x10.5 in the rear and 17x9.5 in the front? hmmm i think the guy from joeandjerrys doesn't know what he's talkin about because he said my cragerSS wheels could olny be 17x9.5 in rear and 17x9 in the front? whats up with that? probably crager olny made them in that size range right?
Old Feb 26, 2008 | 09:07 PM
RS305's Avatar
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
do you need to make any mods such in order to put 18s on? cuz i heard the highest you can do without any mods are 17s
Old Feb 26, 2008 | 09:15 PM
Engine: Tbi 305
Axle/Gears: 3:73s
i done a bit of research in my case 17" are the largest crager ss and for your question you can put 20" on a stock camaro it just depends on the width of your rim and the tire
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
i see people left and right with 18's.. so i doubt there's any mod's needed there.. but i KNOW up front you can run as much as 9.6 width without rubbing.. least that's what les schwab and rim tyme told me
Old Feb 26, 2008 | 10:01 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Looks really good. I like the staggered look with the cowl hood.
You might think about removing the door moldings or at least taking them off to spray back to white, they look yellow in the pictures.
Old Feb 26, 2008 | 10:42 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
jeez ppl, the car isnt THAT high. Looks about stock ride height
looks good, that faded door trim hurts it tho
Old Feb 26, 2008 | 11:25 PM
Car: 92 Z28 Camaro
lol yeah the door trims coming off and the door handles are getting shaved and the whole car is gonna get a new paint job thinking about that new yellow that chevy is putting on some of there colorados not sure the paint code or name though
Old Mar 1, 2008 | 08:31 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Rims look nice. I like the staggered sizing combo.
Old May 12, 2008 | 10:33 AM
maniacmotors's Avatar
Want a title? Post!
Car: 1989 Camaro IROC-Z
Engine: 5.7 TPI
Transmission: built 700-R4
Just wondering what you are running for tire sizes and what you used for spacers because I wanna run this same setup, also do your rear tires clear the inside fender lip? thanks
Old May 12, 2008 | 07:44 PM
Car: 92 Z28 Camaro
on the rear i'm running 295/35/R18 and on the front 265/40/R17 i have 2" spacers on the rear and 2.25" on the front the rear doesn't clear the fender lip that good so i'm having the spacers machined down to 1.75"
hope this helps oh yeah the backspacing on all 4 wheels are 56mm
Old May 13, 2008 | 04:07 PM
Want a title? Post!
Engine: 5.7 TPI
sweet thats wider than I was expecting, any rubbing in the front? ebay wheels are +54mm on the 17's and +58mm on the 18's. Where did you get yours?
Old May 13, 2008 | 07:46 PM
Car: 92 Z28 Camaro
theres no rubbing in the front at all with 2.25" spacer with the 2" ones it will rub the tie rod end with a 56mm backspacing.. i got em from this place.. http://stores.ebay.com/O-E-Wheels i would suggest calling them they are really friendly and give you more options than whats listed on there auctions.. shipping was fast and i had the tires mounted and balanced so they was ready to just bolt on to my car when the ups guy showed up..
hope this help
Old May 14, 2008 | 04:02 PM
Want a title? Post!
Engine: 5.7 TPI
hope this help
Why did you go to 2" if 2.25" was working well, thanks for all the help by the way
Old May 14, 2008 | 04:15 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
he's running 2" up front and 2.25 in the rear. but said it needs shaved down to 1.75 (would 2" work on the back instead of 1.75"?) I am thinking of using th eregular c6 5 spoke rims and already have 4 2" spacers
Old May 14, 2008 | 07:31 PM
Car: 92 Z28 Camaro
i'm running 2" on the rear and 2.25" on the front.. i need 1.75" on the back so it won't hit the fender lip it just barely touches on a hard bump
and on the C6 5 spoke rims it would depend on your backspacing but they should work for ya
Hotrodboba400
Dec 10, 2019 07:07 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
