Need Cam Info
Old Jul 28, 2008 | 10:12 PM
Gary/Pam91Z28's Avatar
Car: 1991 Camaro rs
Engine: 305 TBI
Transmission: WCT5 Rebuilt by Astro
Axle/Gears: Borg Warner posi disc 3.27
Need Cam Info
What performance gains could i expect from installing the high performance 245 hp factory cam in my tbi equiped '91' 305? potential problems? would i need to change the 'chip' or entire computer? fuel system?
these computer cars r new 2 me so be kind with your remarks
Old Jul 28, 2008 | 10:21 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Need Cam Info
FYI...The 350 TPI cam is the same as the 305 TPI (manual) cam.
Why not get an LT1 cam - $40.00
Replace the springs (to ZZ4 specs), retainers and locks...you can get them from GMpartsdirect.com - about $70.00 for everything.
You would need a new chip or retune.
Shold be good for an extra 25-30 hp or so.
Old Jul 28, 2008 | 10:35 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Need Cam Info
This is the appearance section, would would prob get better answers by posting this in the TBI section.
Old Jul 29, 2008 | 01:20 AM
Car: 1991 Camaro rs
Engine: 305 TBI
Re: Need Cam Info
as i have TBI not TPI and the 305 170 horse set-up that comes with it, i was more or less questioning the additional performance if any that might be gained from the HO cam and lifter swap. not looking to change the TBI at this time?
Old Aug 2, 2008 | 03:34 AM
Car: 89 IROC
Re: Need Cam Info
Go to the article section off the main page and look up the "Ultimate TBI mods".
A LT1, 350 TPI cam will still work as a good swap along with a cat back (flowmaster), convert to dual cats, headers, gears (3.42),and upgrade the injectors and/or throttle body (Holley 670 cfm) and intake (Edelbrock).
For more help post up in the TBI section.
junkcltr
Aug 2, 2019 11:12 PM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
camaro71633
Sep 1, 2015 10:24 AM
ambainb
Aug 29, 2015 12:43 AM
