My 88' camaro project begins *update 6/15/09
Old Apr 12, 2009 | 07:49 PM
Tragic_Hero's Avatar
I bought an 88 camaro with a v6 2.8L about a year ago and have been using it as a daily driver. It only has 85,000 actual miles in it and the engine is still solid. However, I don't know much about cars and wanted to use this as the best/worst learning experience ever so I decided to put a 350 in it and change it to carb. I just got back from Hardy, Arkansas to pick up my first ever 350 and next weekend I plan to install the valve covers and paint the engine...any tips on these steps would be greatly appreciated...here are some pics
Here's the engine before being wrapped up
And it will someday replace this...
Here are some over all pictures of the car
I just replaced the speakers and put in a cd player but haven't taken pictures of that yet.
Old Apr 12, 2009 | 07:57 PM
86transam.man's Avatar
Car: 1986 Firebird Project
Engine: 3.1L
Transmission: t5
Re: My 88' camaro project begins
Well first of all you'll need a new transmission. Even with a different bell housing the gearing is different.
Old Apr 12, 2009 | 08:31 PM
Thanks for the advice. I know i want a t56 set up im just not sure when ill be able to by it. I want to finishe the engine completely before i get the transmission.
Old Apr 12, 2009 | 08:35 PM
Engine: 3.1L
Transmission: t5
Also I'm sure you already know, just making sure and for others, but you'll need a different radiator and front springs and engine mounts.
Old Apr 12, 2009 | 09:10 PM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
I do like your car, I wouldnt mind haveing a v6 with a 5 speed.
Old Apr 12, 2009 | 09:39 PM
I looked up most of the swap threads so i have a good idea of what needs to change just not the know how to accomplish it. Have ya paintedthe egine before and know any tricks?
Old Apr 12, 2009 | 09:41 PM
Thanks, is that what you have?
Old Apr 12, 2009 | 09:50 PM
Curtisyz54's Avatar
me? no
I have a 86 iroc 305, auto.
and a 89 Rs 2.8 But its a Auto, Id like a stick.
But The car is a peice of crap.
Old Apr 12, 2009 | 09:58 PM
Engine: 3.1L
Transmission: t5
I looked up most of the swap threads so i have a good idea of what needs to change just not the know how to accomplish it. Have ya painted the engine before and know any tricks?
When I painted mine I just used engine spray paint from Oriely's and masked everything off good. You never want it inside the engine or on any gasket surface because that will lead to trouble. You can use sacks from Walmart or something to help mask too, and if you do get some in there just use Acetone or something like it to clean it off. Good luck
Old Apr 12, 2009 | 10:22 PM
shadowknight's Avatar
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
did ya forget to set the e-break in the 4th pic?
Old Apr 12, 2009 | 10:25 PM
Didnt know abouy the gasket surfaces or the acetone thanks.
Old Apr 12, 2009 | 10:27 PM
Originally Posted by Curtisyz54
me? no
Oh, plan on changing it? Id offer mine but i dont know how long it would last
Old Apr 12, 2009 | 10:29 PM
no, it was engaged just looks it
Old Apr 12, 2009 | 11:11 PM
Curtisyz54's Avatar
no, the car is to rusty, im stripping it now, and im prolly going to junk it.
Old Apr 13, 2009 | 03:45 PM
Engine: 3.1L
Transmission: t5
Your not around the OKC area by chance are you? I'd be interested in changing mine depending on what you'd want for it and where your at?
Old Apr 13, 2009 | 04:31 PM
Im on the Ark-La-Tex border im about 4-5 hours away from OKC. I'm not expecting a lot out of it, but I did just put in a brand new clutch and flywheel just about 4 months ago so those are definitely in good shape. If you're willing to drive that far I'm sure we could work something up.
Old Apr 13, 2009 | 04:34 PM
just googled it 307 miles away, it says 4 hrs and 56 minutes but anyone doing over 60 can shave a little time off.
Old Apr 13, 2009 | 09:59 PM
Engine: 3.1L
Transmission: t5
Alright thanks I will keep an eye out for a classified if you do decide to sell it after your swap. And definitely good luck.
Old Apr 14, 2009 | 11:41 AM
Thanks , im gonna need it
Old Apr 14, 2009 | 12:24 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Just make sure it's extremely clean and oil free before you paint it. If it already has some paint on it as it appears to scuff the old paint before applying the new. Tape off everything you don't want painted carefully.
Old Apr 14, 2009 | 03:53 PM
Engine: 3.1L
Transmission: t5
OH Yes as 89RsPower! said CLEAN CLEAN CLEAN !!! Dust is your enemy cover it with a trash bag when your not working on it! Then before you assemble it oil internal parts that'll help with initial start-up.
Old Apr 14, 2009 | 07:08 PM
The internal is already oiled up, that's ok just wipe excess oil away from where I want to paint it, correct?
Old Apr 14, 2009 | 07:09 PM
whats the best thing to scuff the already applied paint with, last question for now
Old Apr 14, 2009 | 07:31 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Generally a 320grit sand paper will do the job for scuffing old paint to get the new paint to adhere properly.
It'll be a fun project forsure!
I got my iroc-z when i was 15 for $1800. started learning the basics, like brake jobs, tune up etc. Decided i wanted to go deeper so i cammed the 305 that was in it, then with some help from dad we painted it and had it ready for me to get my licence @ 16.
Long story short, the mod bug bit me, and it bit hard. At 18 now ive got an LS2/T56 w/ CNC Heads, BIG cam, Intake, custom exhaust, big brakes etc etc etc. Basically every penny ive earned in the last 3 years.
Definately fun cars to learn on! Lots of parts around, lots that can be modified, and rather cheap to build! (especially Gen1 motors, LSx's are expensive to mod!)
Old May 2, 2009 | 01:25 PM
accidental double post
Old May 2, 2009 | 01:26 PM
Ok finally got it in my spare bedroom and did a little rust removal and found the VIN finally and it's a 74 4 bolt 350 that was in either a c-10 or a 1500 . Painting in 2 weeks once college is out for the summer. I just don't have time with it being finals.
Old May 2, 2009 | 05:39 PM
Engine: 3.1L
Transmission: t5
Re: My 88' camaro project begins *update 5/2/09
Looks Good
Old Jun 15, 2009 | 05:43 PM
Sorry
Re: My 88' camaro project begins *update 6/15/09
Finally got to paint. I just recovered from surgery..nothing major. So here it is
Did this in the spare bedroom man that was a tape off job
First the primer coat
Then the lovely chevy orange
Some of the tape pulled off
Old Jun 15, 2009 | 06:27 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
looking good.
Old Jun 15, 2009 | 08:03 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
yes it does i cant wait for more updates keep us posted
Old Jun 16, 2009 | 08:09 AM
1Aauto's Avatar
Former Sponsor
Man there's nothing like a nice fresh motor.Looks great
Old Jun 16, 2009 | 07:14 PM
Thanks everyone, my next purchase will be the air intake manifold / carburetor which will be close to september maybe a little sooner depends on how well this new job goes.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
