New Pics Of My Car Lowered
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
hey fellas well i decided that i didnt really like the stance of my car. previously when i bought the car it came with sportlines except for some reason the rears where cut, which made my tires rub and for a very harsh ride, also i had stock sturts and shocks. so what i did was cut the sportlines a 1/4 of a coil and place a set of pro kit springs in the rear, i also put new kyb struts/shocks. overall the only thing that rubs is the new air dam which sit about 2 inches from the ground! let me know what you think.
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
Re: New Pics Of My Car Lowered
SSSIIIIICCCCKKKKKK STANCE
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
PERFECT! loved the old stance, this is even better. can you put up a side by side of old/new?
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Looks GREAT! What are your plans for the air dam? I just lowered mine and my air dam is about an inch off the ground and am debating whether or not to remove it completely, or modify it...
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
the front is about 1/2" an inch a bit too low for my taste, my 91 has roughly the same drop but you can see the entire tire, your fender lip seems to cover your tire partially which makes it look smaller. does your front tires rub
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Mmm, perfect stance! And people try and say you can't drive like that on the street.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Looks great man! You won't bottom out if you don't want to. I.E. don't drive on the crappy roads in your area.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
definatly low, good luck with speed bumps and inclines.
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Looks great! Sits about the same as mine. I just took the rotozip and cut 2" off the airdam. No cooling issues, less scrapes.
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Looks Great! Is the passenger side rear higher than the driver? Mine is/was after i lowered it. Still cant figure out how to even it out.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I plan for a full 2" front and rear drop. I will be using racecraft drop spindles, with ground control weight jacks in the front with 900# springs and a 2" shorter spring in the rear at 200# also with the weight jack system with Koni Yellows all around as well as J&M mounts.
Anyway I am at 27.75" all around from ground to the center of fender. I'd like to be about 25.75-26" from the ground which would net me the stance I want.
So my question is, how far from the ground to the center of the fender does your car sit?
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
perfect stance!
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Well done. Usually when people post that they've lowered their cars, I tell them to keep going. But this is perfect. Props
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
dayummmmmm... i love the tucked rims
my 88 is dropped with Z06's
my 88 is dropped with Z06's Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
looks nice, but seriously, how do you drive on the street with that? The front would get torn up on everything. And if you get "spirited" with your driving, the wheels could get into the fenders
Engine: LSX
Transmission: MN12
hey guys thanks alot for the positive commemts, i think i may end up shaving an inch off the air dam, other than that i havent had and problems with the drop, speed bumps i gotta go on an angle but i had to do that before too, im on the 400/401/427 highways daily so i think i ll be alrite, only the wheel well only rubs on big drops, but i only have the outside bolts on the wheel well plastic so once i put the inner it should tighten up and stop, thanks again for the great comments guys!
Wow that thing is low, I love the looks of our cars lowered but the ride just SUXS bad. I had mine lowerd for some time but I just couldn't handle the ride and no weight transer at the track. But I do love the look
That's looking awesome and I like the smooth side without the moldings. Dang and i just bought 88 up pointy moldings to replace the ugly square ones on my 87. More parts for the shelf then. Your car is a great inspiration. Super clean!
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Stance look killer
Hope those arm rests are holding up
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Looks great. I'd also like to see the before pics.
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Looks awesome! These cars look great as they can from the factory, but when you lower em like you did, wow!
Car: 1992 RS
Engine: 305 TBI
Transmission: Stock Automatic
Axle/Gears: Stock
Super cool ride!! I love the Y2K's...are you running 17's in the front and 18's in the rear? Or 18's all the way around? What size spacers?
Engine: LSX
Transmission: MN12
the wheels are 18x9.5 all way round with 2 inch spacers, 245/40/18 and 295/35/18 here is a pic of the stance before also, i end up trimming the air damn about 1/4 of a inch as it was scraping everywhere lol,, ohh yea bye the way Bill those arms rest are holding up awesome!
dont know about you guys, but i like the before stance better. instead of getting new springs, you should have got the 5 inch spoiler, that would have given that rear lift (raked) look that essentially you got now.
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
i also have a white camaro that i am in the process of building, dont want to steal the stance of your car but if i buy the pro-kit and cut them 1/4" in the back how much would i need to cut to get it that low in the front??
Car: 89' IROC-Z
Engine: LO3
I'd have to agree. But then again, if he lowered his rear how it is now it would be so much better than before (shown above). I like the old and the new.
Engine: LSX
Transmission: MN12
EDIT forgot to add the rear looks off in the pics because that before i adjusted the panhard bar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
I like the stance of yours Pearl. I really think it improves the look, low and sleek. Mine was lowered by a PO but I have no idea how. It's about 1.5" low all around. I like the look of dead-nuts level rather than a aft/fore rake (rather old school). For an old fart like me it makes gettin' in and out of the car a bit of a chore. Wouldn't hurt loosin' the spare tire I'm carryin' 'round with me eh?
I have the usual problems with speed bumps and big driveway ramps etc. A couple of times I've bounced the SFC's off a speed bump. Little un-nerving.
This pic (scan of photo) is of my original '87 shortly after I got it new in '87. You can see the noticeable difference in ride height.
I'm not worrying about cutting down the air dam. It'll eventually get worn down anyways!
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Looks awesome - How does it feel on the street? Toronto roads are dreadful.
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
That really looks good
Tried running mine that low but road conditions around here
would'nt let me and had to raise it back up alittle.
Running Morrison coil overs on mine so pretty adjustable on hieght.
Pics
Later
Pics
Later
Car: 87 IROC-Z
Engine: 5.7 TPI
You've got to be very careful especially with speedbumps & curb ramps. This car doesn't like rough roads but I don't imagine (or I don't remember my other one) most do. The car handles and tracks well maybe a bit better then original. I really like the looks and have been pursuing "all original" with this car but I'm thinking I might leave it this way unless it becomes a real problem.
Car: 1987 Iroc-Z28
Id like mine to be a little lower in the front but i like to way it sits and it ride better than it did even stock. INTRAX springs, now Iso's KYB AGX's on all 4, NO SILLY SPACERS
Engine: LSX
Transmission: MN12
lots of changes since 2009, removed sportlines and installed Eibach Weight Jacks, UMI control arms front and rear, basically rebuilt the front end (tie rods etc) C5 front brake upgrade also added a rear end from a 02 SS with 3.42 gears. Currently working on a Lsx/T56 Swap
This is how it sits as off June 2011
COTM Editor
Didn't know Eibach made weight jacks.... Hmmm
Looks really good btw
Car: 1987 Iroc-Z28
HAHAHA yes, love the stance. I havent even drove my car yet and ive already changed the springs 3 times
