what glue for emblems
Old Sep 3, 2009 | 11:06 AM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
Got it painted, now to put the emblems back on. What do I use in the way of adhesive to install the rear bumper emblem. It originally had a glue backing which is long gone. sticky tape is too thick, soooo silicon or weather strip glue or what?
Old Sep 3, 2009 | 12:13 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
Re: what glue for emblems
i would use the 3m tape.. it comes in different thicknesses, sticks well, and is relatively easy to remove if you ever need to.
Old Sep 3, 2009 | 12:38 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
I'd say epoxy, you can get it at any auto parts store. When I got my new emblems they had the 3m tape on them and in about a week they fell off the car. The only thing they held to was the metal emblem, cause I had to scrap it off. The epoxy works great and it will not have the emblem sticking out like the tape does.
Old Sep 6, 2009 | 09:13 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
You could use 3M double sided tape or 3M also makes a special adhesive just for emblems.
Old Sep 6, 2009 | 09:30 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I used the 3M tape (on fresh paint too) and never had a problem or lost an emblem. Just make sure the surface is room temp. and clean and it will stick forever.
Old Sep 6, 2009 | 12:20 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
the adhiesive they got nowadays is extemely strong, the only way i see it coming off is if you didn't prep the surface correctly
Old Sep 6, 2009 | 01:54 PM
Stephen's Avatar
Car: 87 GTA
Die-cut emblem tape......
http://www.carmotorsports.com/products.php?cat=38
F-body-fan
Jan 12, 2023 01:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
ASE doc
Sep 22, 2015 03:13 PM
