1991 Ground Effects
Old Nov 11, 2009 | 08:41 PM
PontiacGuy1999's Avatar
Want a title? Post!
1991 Ground Effects
Hello Everyone. I'm new to the forums and I really need help. I've got a 1988 Camaro, base model, and I'm thinking about putting a newer style camaro ground effects kit (like a '91 of '92 style). I've looked through Classic Industries and Year One catalogs but it specifies between 1985-1990 and 1991-1992 kits. Do you think that this will work anyways? Thanks guys!
Old Nov 11, 2009 | 09:00 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: 1991 Ground Effects
Welcome to TGO
I will say yeah that they will fit as long as you have all the materials needed to do the installion right. I myself have a 84 camaro that had all the body kit remove and now I am installing the 91-92 kit. They told me that it will fit without no problem as long as I have all the things
Old Nov 11, 2009 | 09:09 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
85-90 and 91-92 will all interchange no problem. exept berlinetta in 85 an 86, they are just like the 82-84, the whole front bumper cover is differant so thatd need swapped out if you wanted to change one of those years.
in your case, just swap and go. i believe you use all of your existing taps, bolts, nuts, ect.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
billybob6110
Sep 23, 2015 01:30 PM
aharvel50
Sep 21, 2015 07:31 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
