removing park lights
Old Jan 14, 2010 | 07:17 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
i was wanting to remove the park lights on my iroc and can someone help me on doing this is it just a easy quick job to take them out and put them back in. step by step please thanks.
Old Jan 14, 2010 | 07:26 PM
Stephen's Avatar
Car: 87 GTA
Re: removing park lights
Look at the back side of them. Pretty self explanatory, once you actualy look & see the clips or nuts, which depends on which lights you are referring to.
Old Jan 15, 2010 | 05:47 AM
Engine: 305TPI
thanks im reffering to just the lower orange park lightes that are common to fog up
Old Jan 15, 2010 | 09:29 AM
Stephen's Avatar
Car: 87 GTA
That narrows it down to one end of the car, at least.....
Nose? Fenders? None of mine "fog up" so that doesn't tell me much.
I asked WHICH lights and you were still cryptic. Bottom line is to LOOK FOR YOURSELF. Look at the front......No clips? No nuts? Look at the back. They are self explanatory if you LOOK..
Old Jan 15, 2010 | 11:01 AM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
if you mean the front parking/signal lights in frnt bumper, they are held in by 3 bolts on the back, once bolts are removed they slide forward remove bulb socket and they're out.
if you mean orange side makers in fender, then they are held in with two small wire clip thingys, just lift up clips wiggel around untill you can get them out then light will fall out,remove bulb socket and they're out.
but like Stephen said stick your head head under your car and take a look, you have to go under there to take them out anyway.
Old Jan 15, 2010 | 11:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by sid rs91
if you mean the front parking/signal lights in frnt bumper, they are held in by 3 bolts on the back...
Two as I recall, one on each side of the housing. Follow sid's instructions and you're good to go.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
