i Got other camaro!! 350 Goodwrench???
Car: 86 z28 IROCZ
Engine: 350 5.7 goodwrench
Transmission: 5 speed
Axle/Gears: g92? and g80 LIMITED SLIP
i just bought a other camaro, a 89 Z28 Irocz. the car has a 4 barrel carb, and a 5 speed trans. But the car had 350 5.7 goodwrench engine? i was looking at the rpo codes and the car orginaly had a 305. If this is a 350 i wounder what kind of horse it makes. the rear end i g80 and g92. i know the g80 is LIMITED SLIP and the g92
i want to know what is limited slip and want kind of gears are in the rear.
And does the goodwrench make good horse?
Re: i Got other camaro!! 350 Goodwrench???
If the car was originally a 305 and has the G92 rear it's probably 3.42 gears. I don't know what that motor makes, the '89 L98 made 230hp/330tq though. Hope this helps.
Car: 86 z28 IROCZ
Thanks but what does limited slip mean on the g80?
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
one tire flyers
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
no limited slip both wheels will spin. its just not true posi
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
most of those goodwrench 350 were rated at 330 flywheel hp
