my winter project progress
Old Dec 30, 2009 | 06:40 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i havent posted pics in awhile, ao i decided i would post some of my firewall ac delete, and battery relocation kit. any thoughts or comments are welcome.
Attached Thumbnails my winter project progress-100_0830.jpg   my winter project progress-100_0831.jpg   my winter project progress-100_0832.jpg
Old Dec 30, 2009 | 06:44 PM
Engine: 355
Re: my winter project progress
a few more
Attached Thumbnails my winter project progress-100_0833.jpg   my winter project progress-100_0839.jpg   my winter project progress-100_0840.jpg
Old Dec 30, 2009 | 06:46 PM
Engine: 355
and my hidden master cutoff switch
Attached Thumbnails my winter project progress-100_0841.jpg   my winter project progress-100_0842.jpg
Old Jan 3, 2010 | 05:51 PM
Engine: 355
wow no responses... anyways i got the engine bay all sanded down, cleaned, prepped with metal ready, and painted with gloss por 15. it looks amazingly shining and smooth. ill post pics when i get some good ones
Old Jan 3, 2010 | 05:59 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Don't be discouraged by the lack of responses, doesn't mean people aren't paying attention. Keep us posted on your progress, looking forward to the pictures of the painted engine compartment.
Old Jan 3, 2010 | 06:12 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I like how you did the master cutoff, any more pics of the inside? did you have to do any clearancing to the plastic panels???
Old Jan 3, 2010 | 06:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
so, how do you get to the shutoff? or is this just a security feature and not a shutoff for racing purposes?
looking good so far
Old Jan 3, 2010 | 06:44 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
I like the shut - off idea.You could just take the panel off to pass tech at the track.
Old Jan 3, 2010 | 08:58 PM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Confused a little bit. (Because I'm New)
So what is the reason for repositioning the battery?
More weight on the back tires?
Old Jan 4, 2010 | 10:07 AM
Engine: 355
looking good so far
i made it so theres only on screw securing the black plastic piece of the taillight. i used a dremel to remove the inside "framing" of the black piece. it sits flush and will never tell its there. basically remove the cover at the track, and put back on when not. keeps touchy peoples hands off it
Old Jan 4, 2010 | 10:08 AM
Engine: 355
moving it to the back gives it better weight transfer, and gives the "torque" side more to work with, having it over the pass side tire
Old Jan 4, 2010 | 10:09 AM
Engine: 355
[quote=1986Z28OWNER;4389440]I like how you did the master cutoff, any more pics of the inside? did you have to do any clearancing to the plastic panels???[/quote
what kind of inside pic u looking for? how it goes threw the rear compartment or behind the light?]
Old Jan 4, 2010 | 06:41 PM
Engine: 355
got some pics of the engine bay!
Attached Thumbnails my winter project progress-engine-bay-1.jpg   my winter project progress-engine-bay-1-2   my winter project progress-stairview.jpg
Old Jan 4, 2010 | 06:43 PM
Engine: 355
first pic is the block off plate, and the others are with rustoleum aluminum. not sure if i like the brake booster aluminum
Attached Thumbnails my winter project progress-block-off-plate.jpg   my winter project progress-brake-booster.jpg   my winter project progress-powersteering.jpg
Old Jan 12, 2010 | 07:34 PM
Engine: 355
well beem at sort of a stand still with getting things done in the engine bay. for one i need my engine in so i can run the rest of the fuel lines and etc. but got the fuel regulator ran, and just gotta tie it into the hard line for the fuel. got some more pics of the engine bay below. also got my trans rebuilt with shift kit, corvette servo, and changed the 7 vane out for a 10 vane. hope itll liven it up a lil! keep comments coming!
Attached Thumbnails my winter project progress-f.p.r-1.jpg   my winter project progress-f.p.r-2.jpg
Old Jan 12, 2010 | 07:38 PM
Engine: 355
misc pics of my engine rebuild start and tranny after rebuild
Attached Thumbnails my winter project progress-engine3.jpg   my winter project progress-engine-1.jpg   my winter project progress-tranny.jpg
Old Jan 12, 2010 | 08:12 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Looking good. Keep it up.
Old Feb 9, 2010 | 07:13 PM
Engine: 355
ok update on the car. i got me a 355 motor over the last weekend, got it stripped painted and slowly putting it back together, taking my time so i dont gotta do it twice. ill post pics of the engine tomorrow when i upload them in my computer...
tmellott89
Oct 14, 2015 02:06 PM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
