The 88 Carmaro Rebuild... :O
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Re: The 88 Carmaro Rebuild... :O
Welcome to TGO, sounds like the guy you got your car from is a Tool, but anyways it should be a fun project. good luck !
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Spray plenty of PB Blaster on all the bolts you're going to be removing!..
Yes, even the one in the pic!!
Your knuckles will thank you!!..
If you are wanting stock replacement, try the " Parts for sale " threads, or a U-Pull-It // JY, Third Gen Ranch, Hawks, maybe 1AAuto.
Or if you want NOS lines // tubes, try somewhere like In Line Tube.
Fun winter project!!
( edit )
After you soak that trans line with PB, try to use a small vise-grip type of pliers.
( edit )
TomP
May 20, 2002 03:26 PM
