My 1986 Z-28 build thread *PIC HEAVY*
#501
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: My 1986 Z-28 build thread *PIC HEAVY*
6.0" connecting rod so the dwell time at tdc is a little higher. Its definitely in cam timing events. The only solution may be a cam change.
#502
Thanks for the feedback. This latest build has been a pain in the ***. I hope to sort it out over the winter and be good to go next season.
Looking forward to your new engine build.
#504
Car: 1979 Malibu
Engine: Blown LSx
Started fixing up the set of Brodix heads going on this engine, one casting was good, the other one however... not so much. It became the victim of a dropped intake valve.
Seats cut out and major damage ground out. Ready for welding.
#505
Wow. Is it worth it? I suppose working in an engine shop has it's advantages though.
#506
Car: 1979 Malibu
Engine: Blown LSx
Well a replacement casting from brodix is about 700$, all im going to have into this one is the cost of seats and guides.
#507
I was thinking more along the lines of what it would cost for a guy like me to have that head saved. There's a lot of time and skill that's going to go into that head with welding, milling and grinding.
Then again, like I said, working in an engine shop has it's advantages.
#508
Car: 1979 Malibu
Engine: Blown LSx
Started pulling the engine out the car last night, should come out tonight.
#511
Car: 1979 Malibu
Engine: Blown LSx
Also, it's the last day to vote for Car of the month! go vote for your favourite car!!! https://www.thirdgen.org/forums/auto...ng-2013-a.html
#513
Want a title? Post!
Car: 85 Camaro
Engine: 79 454
Transmission: Th400
Wow amazing build. A lot of great work. I like to see fellow Canuck so well represented. I bought my Camaro this summer and it looks more like your first post! Seeing yours coming together makes want to get after mine!
#515
Car: 1979 Malibu
Engine: Blown LSx
Finished pulling out the engine and trans, sold lots of parts off the current combo. ordering lots of new parts for the new combo. Should have a nearly complete engine by christmas if all works out.
Sold the TKO600!!
I also cleaned up and inspected the old engine, everything checked out fine and I gave it some fresh plugs, oil and filter and it's now for sale. $6000.00 OBO
Sold the TKO600!!
#519
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Did you ever take the old combo to the track and get some timeslips?
#521
Car: 1979 Malibu
Engine: Blown LSx
Yeah, ran it twice. tko gave me grief with the 60 foot. best it ran was 12.24 @ 116mph with a 1.935 60 foot. not bad for 3700lbs lol
#522
Car: 1979 Malibu
Engine: Blown LSx
More shiny parts arriving.
Treadstone 1300hp 2 to 1 intercooler
PSI MaxLife valve springs for solid roller
Xceldyne Lightweight titanium retainers
#523
Car: 1979 Malibu
Engine: Blown LSx
More and more shiny parts arriving daily.
Ferrea Comp plus stainless intake valves, I am also running Ferrea Super Alloy exhaust valves
Crower solid roller HPPO lifters
ATI super damper
Tial knockoff BOV
ARP main studs installed
Frost plugs installed, ready to pur some hard blok
Mixing up the first batch of hardblok
First side poured and torque plate torqued up. I poured both side this weekend but didnt feel the need to document both sides...
[/URL]
I also got some specs on the new cam, I had Lil Johns Motorsport Solutions spec the solid roller out for it, He does alot of turbo combo's and his camshafts seem to work quite well. It's a Bullet grind 0.683"/0.683", 261/265 @0.050", 115+4 LSA. Should be pretty nasty.
ATI super damper
Tial knockoff BOV
[/URL]
#526
Car: 1979 Malibu
Engine: Blown LSx
Christmas came early!!!!
Twin Borg Warner S366's 0.91AR
Edelbrock single plane EFI with elbow and 90mm throttle body
Cometic head gaskets
#529
Car: 1979 Malibu
Engine: Blown LSx
http://www.ebay.com/itm/Silver-50mm-Blow-Off-Valve-35-PSI-Turbo-Boost-CNC-V-Band-Spring-Weld-/131050159775?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e8332be9f&vxp=mtr
#530
Car: 1985 trans am
#531
Car: 88 iroc-z
Engine: 350 tpi
one of the best builds i have seen in a long time. . . great work man keep it up
#532
Car: 1986 Camaro, 2004 9c1 impala
Engine: TPI 350, previous owner hackjob
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
WoW keep up the good work!
#533
Car: 1979 Malibu
Engine: Blown LSx
Well... Things took a turn for the awesome yesterday. picked up a set of CFE/BMF 18 degree heads. this thing should make some pretty killer power now...
Might need a lower profile elbow to clear the hood....
Xceldyne belt drive.
new camshaft from Lil John Motorsports Solutions
Should sound pretty badass through dual 4" downpipes dumped under the fenders
And some shiny bit's to match the new paint.
#535
Car: 1979 Malibu
Engine: Blown LSx
I may, Just for the sake of not blowing another 600$ I may run it this year. Even with the camshaft being a poor match It will be making more then enough power for the block to handle. Next winter I will likely upgrade to a Iron eagle or Little M with a 55MM cam tunnel and 0.937" keyway lifters.
#536
Car: 1979 Malibu
Engine: Blown LSx
More parts...
New transmission specialties Reid case powerglide
B&M pro bandit stealth shifter
T&D shaft mounted rockers for the 18 degree heads
#537
That's quite the collection you have there.
What became of the Brodix head you were working on?
#538
Car: 1979 Malibu
Engine: Blown LSx
I will likely finish fixing them and sell them.
#539
Car: 1979 Malibu
Engine: Blown LSx
well, more and more small parts arriving daily. I have a potential buyer on the old engine and if everything works out I will be able to buy the remainder of what I need to finish this thing up.
Ferrea Comp plus intake and Super Alloy exhaust valves.
Crower hi seat offset solid roller lifters
2.5lb co2 bottle kit for boost controller
Aeromotive fuel pump controller
Strange double adjustable coil overs w/ 175lb hypercoils
Reid roller tail housing for the glide and MW billet slip yoke
Tubular k-member
FAST fuel rails
Tubular k-member
FAST fuel rails
#541
Car: 1979 Malibu
Engine: Blown LSx
So I have been flopping back and forth between wet sump and dry sump and I finally came to a decision this weekend... DRYSUMP!
Dan olson aluminum pan with one piece billet rail
New Barnes 3 stage drysump pump.
Pan cleared the K-member with zero modification.
#542
Car: 1983 Camaro Z28
Engine: 383 Stroker
I still love what you're doing here, been a while since I checked this out, you've made alot of progress and it's coming along great! Awesome build!
#543
Car: 1979 Malibu
Engine: Blown LSx
Small update... more parts arriving. I intend on stripping the panels back off the car to prep it for paint and take the plasma cutter to the front end to male some room the turbo kit and drysump setup.
Dual transmission coolers because I intend on street driving this thing a lot. And locking trans dipstick.
2.5gallon meth tank for street driving.
rebuilt the t&d rockers. Changing the exhaust rockers to match the intake rocker ratio, had to replace one shaft.
Got the correct brackets for my barnes pump and test fit everything with the k-member...
#545
Car: 85 IROC Z-28
Engine: 327
This build is going awesome, congrats! But how did you fab the radiator support so you can remove it for ease of engine access? did you just cut and make tabs? If you have covered this already i'm sorry but i read through it pretty quickly in between classes the other day and found myself reading it again today!
#546
Car: 1979 Malibu
Engine: Blown LSx
Sold the old engine and got some more parts in.
Billet 1x cam sync distributor.
holley 58x crank trigger. Has some slight clearance issues with the drysump scavenge fitting.
Logged the rod bolts on the rods and honed the small ends for proper pin bore clearance.
Got my 1.6 ratio exhaust rockers and got those installed.
#547
I really liked that old engine. Any idea what it's going to be installed in? (I'll be cruising Edmonton in June. Might be a good race depending...).
You've got a lot of work in front of you. Any projected completion date?
It all looks like great stuff. Long live the Gen 1 SBC.
#548
Car: 1979 Malibu
Engine: Blown LSx
It's goin into a late 70's second gen, out in Nova Scotia. Goal is to make the first local outlaw 8.5 race June 14, but that's being very optimistic.
#549
Car: 1979 Malibu
Engine: Blown LSx
Custom pistons are here from Diamond for my new engine! 2618 Material, inboard pin boss design, 0.927" x 2.25" x 0.225" H-13 tool steel pin, Hard anodized.
strange double adjustable shocks also arrived.
#550
Car: 1979 Malibu
Engine: Blown LSx
Last night I did some drysump pan surgery, the crank trigger bracket didnt clear one of my scavenge fittings on the pan, so some surgery was in order.
The clearance issue...
Took this trashed pan and stole some fittings from it.
My good pan, before cutting it up...
Big ole hole cut in the side, revealing the top scavenge line...
Fitting in place
Line re-routed, needs some minor fit and finish work and final welding and the pan will be ready for powdercoating.
All ready for welding.
This took about 4 hours in total, I was nervous about cutting the pan up, but it worked out quite well.
Fitting in place
